997 : 2004- 71
Boxster : 1997- 13
NedHan79
PostPosted: Fri May 03, 2019 9:30 am    Post subject: Which bushes? Reply with quote
Mot’s up at the end of June. I need brake pipes, aos, clutch and a few other bits so I’m going to pull the engine and box and sort anything else that needs doing. I’m going to strip the suspension to sort a lot of worn bushes. I’ve decided to stick with the m030 shocks for now as they seem to work fine and I don’t have the budget now for new stuff.
The big question is, and I’m sure it’s been asked here countless times is, standard or polybush?
I might completely re-do the rear. I’m lowered so will need to look at adjustable toe arms.
Has anyone any idea of cost comparisons for standard vs poly?
I want as much feel as possible from the car and might go down the coil over route at some stage.
But I don’t want it brutally hard. The odd track day is a possibility but more Irish back roads on the weekend would be the norm. I want to start gathering parts so keen to find out
I’m thinking of just getting new Meyle arms for the front but could be persuaded to poly bush it very easily as it’s cheaper.
As usual, all advice welcome
#modified996mk1
maldren
PostPosted: Fri May 03, 2019 2:47 pm    Post subject: Reply with quote
If you're going Polybush, consider Spyder as well.
Mike
NedHan79
PostPosted: Fri May 03, 2019 2:48 pm    Post subject: Reply with quote
Sorry mike, I’m not with you. Spyder?
#modified996mk1
Griffter
PostPosted: Fri May 03, 2019 3:14 pm    Post subject: Reply with quote
Spyder (I think it’s a trading name of ePorsche but someone please correct me if I’m wrong) sell ready poly-bushed arms on eBay. I had them in my watch list but can’t find them now. IIRC it was about £500 for everything. Seemed like the best most straightforward option to me.
Anyone got a link?
rdodger
PostPosted: Fri May 03, 2019 3:40 pm    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Porsche-996-Coffin-Lower-Control-Arm-Tuning-Fork-X-4-With-Power-flex-Bushes/332716273663?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri May 03, 2019 3:48 pm    Post subject: Reply with quote
Have a search for Spyder coffin arms on here, the bush fitment isn't quite right.
maldren
PostPosted: Fri May 03, 2019 4:17 pm    Post subject: Reply with quote
I think the bush issue has been solved but check them out.
I bought a full set of arms (inc tuning forks) but not the poly bush versions. They're fine and CG were very happy to fit them.
Dean is a good guy to deal with too. No links to them, just a happy customer.
Mike
Mike
NedHan79
PostPosted: Fri May 03, 2019 4:26 pm    Post subject: Reply with quote
I’m more than happy to change the bushes myself as I’ll have it all out anyway. I was more thinking about changing all the bushes in the rear. Think I saw a kit with all of them poly for around £600 iirc. Maybe that was just for the rear.
#modified996mk1
NedHan79
PostPosted: Fri May 03, 2019 4:27 pm    Post subject: Reply with quote
Possibly sub frame bushes in that too
#modified996mk1
