997 : 2004- 74
Boxster : 1997- 14
steve r
PostPosted: Wed May 01, 2019 8:15 pm    Post subject: C4S / Turbo / 40AE Fan resistor change Reply with quote
It looks like the radiator fans aren't working on the low speed on my 40AE, the high speed is fine so I think I need too change the resistors. These are different on the C4S / Turbo / 40AE to the standard Carrera ones that can have alternatives spliced in.
Is there a similar alternative for these resistors or is it genuine parts only?
40th Anniversary
PostPosted: Thu May 02, 2019 7:11 pm    Post subject: Reply with quote
I have to admit .. i've never changed one of these so i can only assume they are pretty reliable ..
i would think its porsche parts only ..
I had a route around and found a wiring diagram if its of any help , its from a Turbo but as close as i can find to this system .. i'm pretty sure they are the same ...
 Filesize:  313.52 KB
 Viewed:  413 Time(s)
steve r
PostPosted: Thu May 02, 2019 8:20 pm    Post subject: Reply with quote
Thanks for the reply and for the wiring diagram. It confirms what i'd read today that the Turbo fans have 3 speeds rather than the 2 of the Carrera.
I'm now not 100% that I have a fault as I only assumed I did due to playing with my Durametric and nothing happening when I clicked on the low speed activation option, the fans activated when I clicked on the high speed option though. It's possible that the durametric can't activate the 3 speeds of the turbo fans, i'll try to have another go this weekend. I can always make up a jumper wire to test the speeds with each relay removed.
I think you're right about these being more robust as theres very little info online about them going wrong when compared to the Carrera resistors.
40th Anniversary
PostPosted: Fri May 03, 2019 7:35 pm    Post subject: Reply with quote
To be honest .. i don't think you have a fault .. even with the tester i use .. not cheap ones then activations of items are a bit hit and miss .. and i use the Porsche system testers as well .
if the higher speed works then you don't really have a problem as such .. the car can cool if needed and as i said i've not had a problem with these as of yet so its leaning towards a tester fault and not the car i would guess at .
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri May 03, 2019 7:47 pm    Post subject: Reply with quote
Can’t you test the low speed operation by switching the air con on?
