Boxster : 1997- 20
marko343
PostPosted: Wed May 01, 2019 7:24 am    Post subject: Coffin Arms Reply with quote
Morning,
The front and rear coffin arms/wishbones have different part numbers, are they different sizes or are they both the same?
The reason I ask is I have seen a full set for sale which states they fit front/rear and left/right
TIA
PostPosted: Wed May 01, 2019 6:16 pm    Post subject: Reply with quote
Rear is different to the front ..
No. 21 here ..
https://www.deroure.com/diagrams.asp?TBL=2821&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
Front and there is one type for all models ..
https://www.deroure.com/diagrams.asp?TBL=2810&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
ThomasG
PostPosted: Thu May 02, 2019 5:32 am    Post subject: Reply with quote
I had a look at the Wishbones installed in my 06 Carrera. All of them have the same part number engraved. I think, this number just refers to the aluminium part of it. The difference between front/rear are the mounted bushes.
You can see it on some photos posted on the internet. One of them has round holes, the other one looks like a keyhole.
Porsche sells different parts for front/rear. Also Meyle lists different parts. Both have also differences for Coupe/Cabrio/Targa.
Only cheap sources recommend to use one part for all three corners. I guess they will work as the overal geometry is the same. But they might lead to less comfort or durability.
Thomas
marko343
PostPosted: Thu May 02, 2019 4:43 pm    Post subject: Reply with quote
Many thanks for the replies Thumb
