997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
acer54
PostPosted: Tue Apr 30, 2019 3:14 pm    Post subject: Lumpy when cold Reply with quote
My 3.2 V6 is always a bit lumpy when cold but once it's warmed up it goes like a rocket, any ideas as to what could be causing it?
2005 Porsche Cayenne V6 3.2 Litre
PostPosted: Tue Apr 30, 2019 7:57 pm    Post subject: Reply with quote
i'm afraid that's an absolute needle in a haystack ..
Fouled plug , old plugs poor injector spray pattern ... a coil faulty , secondary air injection fault .. valve timing .. i could go on to be honest ..
I would sit there looking at the engine values on a tester and probably over several mornings to try and figure out what might be causing it .
not something i can give an answer to Sad
Indy Mechanic .
acer54
PostPosted: Wed May 01, 2019 12:19 pm    Post subject: Reply with quote
It's not registering any codes either which makes it more difficult to diagnose as well.
All plugs were changed last October and coil packs on cylinders 2,3 and 6 were changed (maybe the unchanged coil packs should be changed)?
MarkGolf
PostPosted: Wed May 01, 2019 12:29 pm    Post subject: Reply with quote
Going back to my VR6 days, lumpy when cold was always an air leak after the MAF or secondary air pump.
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
acer54
PostPosted: Wed May 01, 2019 2:24 pm    Post subject: Reply with quote
I'll have that checked, also it's been pointed out if the idle speed is the same hot or cold and I can confirm that it is, opinion is that it should be elevated during a cold start until engine is up to temperature.
Once engine is up to normal temperature it runs normally.
MarkGolf
PostPosted: Wed May 01, 2019 3:58 pm    Post subject: Reply with quote
Yeah, VR6's do that, funnily enough, I spent yesterday adjusting the cold idle on my VR6. In the current temp, it idles at 1050 on the cold map and then drops to just below 800.
I used to have an issue with being lumpy when cold and resolved that over Christmas by replacing the intake manifold gasket.
1 big thing I forgot which effects the VR6, R32, is the PCV, these always break and introduce an air leak.
Provided the plugs/coils aren't old, then the above would be where I'd be looking.
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
