991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
Basalt911
PostPosted: Sun Apr 28, 2019 8:23 pm    Post subject: To DRL or not Reply with quote
A few years ago I fitted my 997.1 with some Design911 DRLs. They certainly gave the car a fresher, more modern look
Now, one of the indicators appears to have blown and I'm not sure how much of hassle it'll be to replace. Has anyone had to do this?
That said, I'm also starting to think about returning the original side light/indicators in an attempt to keep the car super original and period
Interested in views on which way to go...
Basalt911
PostPosted: Mon Apr 29, 2019 10:58 am    Post subject: Reply with quote
spoken to Design911 and they are, indeed a sealed unit, so I need to buy new DRLs (if I want to stay down the modern vs. original look)
problem i now have is getting the DRL out...it feels really firmly fixed and don't want to do damage getting out - I've put the credit card thingy into the release lug but it feels pretty stuck
any tips?
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Mon Apr 29, 2019 4:29 pm    Post subject: Reply with quote
Agreed - its not that easy....
I take it you've read the page in the manual to see the spot where you push to release?
I found it was better to use 2 x old credit cards than the thick release card.
Easier to release when the plastic tab is warm too.
Basalt911
PostPosted: Mon Apr 29, 2019 6:18 pm    Post subject: Reply with quote
i'm currently using one credit card, so maybe it's not thick enough...but yes, in the right spot per the manual
Basalt911
PostPosted: Tue Apr 30, 2019 11:41 am    Post subject: Reply with quote
happy days - two scuffed knuckles and the DRL is out
even happier - a wiggle of a wire, and the indicator works again
I am a technical god
Poker2009
PostPosted: Sat May 04, 2019 8:18 am    Post subject: Reply with quote
I've had Dectane side repeaters and rear lights (Gen 1) for a couple of years - was always in two minds about them.
What I also found is the water just doesn't drain properly - there is no substitute for original parts.
I swapped out for Porsche all red rear lights, the original side repeaters and never looked back since.
997.1 C2S, black, coupe, manual, Feb '05:
65k miles, tiny IMS bearing, Millers NT+ 10W50, driven above 3000 RPM.. original engine.
Basalt911
PostPosted: Thu May 09, 2019 3:26 pm    Post subject: Reply with quote
mine stopped working after a jet wash...
mkoenigsheim
PostPosted: Fri May 10, 2019 1:15 pm    Post subject: Reply with quote
I actually have the OEM removal "tool" and can confirm it is way stiffer than a single card. Put 2 back to back and you are about right...
