991 : 2011- 19
997 : 2004- 76
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
pietrzj
PostPosted: Sat Apr 27, 2019 7:41 pm    Post subject: Fan Belt warning switch - Fixed Reply with quote
All,
I had the warning light come on recently. Not on all the time, just occasionally and more frequently this last week. I changed the belt a year or two ago and visually it was fine, but looked fine when I checked it this week other than a bit slacker than 5mm so I took a shim out. No change the the warning light so I dug deeper.
The switch itself is not a sealed unit and is only held on with one alan stud, so was easy to remove and strip down.
It was then obvious that it could not have been triggering due to a slack belt as the cam travel of the switch really only activates over large distances i.e when the belt has snapped.
I tested the resistance across the two pins and found it was not a clean closed circuit. The resistance was varying from 10s of ohms to 0.1 ohm. So the fault was within the microswitch itself.
I carefully removed the microswitch and cable assembly by scraping to top of the two plastic pins and sliding it up and out.
I then cleaned the whole unit up and, using contact cleaner, soaked the switch such that the tiny pin actuator was submersed as I operated it manually to ensure the contact cleaner got right inside.
I left it submersed in the cleaner (using the lid as a container), over night and dried it off in the morning. The resistance was now a solid change between 0.1ohm and infinity when operating the switch - Fixed!!!
Reassembly was straight forward and for good measure I greased up the bearings in the plastic wheel.
The saved me £77 + VAT for a replacement part, so well chuffed.
Really easy fix, so if you get something similar and its not a missing fan belt. Give it a go.
Hopefully the photos will help...
 Filesize:  1.35 MB
 Viewed:  2399 Time(s)
pietrzj
PostPosted: Sat Apr 27, 2019 7:42 pm    Post subject: Reply with quote
Microswitch
 Filesize:  1.26 MB
 Viewed:  2397 Time(s)
pietrzj
contact cleaner
 Filesize:  1.71 MB
 Viewed:  2395 Time(s)
pietrzj
PostPosted: Sat Apr 27, 2019 7:43 pm    Post subject: Reply with quote
microwitch cleaned
 Filesize:  1.62 MB
 Viewed:  2393 Time(s)
pietrzj
PostPosted: Sat Apr 27, 2019 7:47 pm    Post subject: Reply with quote
microswitch re-fitted
 Filesize:  1.13 MB
 Viewed:  2386 Time(s)
pietrzj
PostPosted: Sat Apr 27, 2019 7:49 pm    Post subject: Reply with quote
re-assembled
 Filesize:  915.18 KB
 Viewed:  2383 Time(s)
pietrzj
rear
 Filesize:  1.94 MB
 Viewed:  2381 Time(s)
pietrzj
PostPosted: Sat Apr 27, 2019 7:50 pm    Post subject: Reply with quote
contacts to test
 Filesize:  1.55 MB
 Viewed:  2379 Time(s)
pietrzj
PostPosted: Sat Apr 27, 2019 7:51 pm    Post subject: Reply with quote
Refitted - Job Done.
 Filesize:  1.86 MB
 Viewed:  2375 Time(s)
Cameltoe & Heel
PostPosted: Sun Apr 28, 2019 7:38 pm    Post subject: Reply with quote
Love these posts, well done sorting it out. I did a similar thing with mine, although I had to lube the wheel up as it was getting s bit sticky.
Trev
Luddite
PostPosted: Sun Apr 28, 2019 8:15 pm    Post subject: Reply with quote
Great job peitrzj you have covered the whole task very well, good pics too .... when the switch is in position on the car correctly adjusted, are the contacts opened or closed....?
alex-j
PostPosted: Mon Apr 29, 2019 11:25 am    Post subject: Reply with quote
Nice work Thumb
pietrzj
PostPosted: Tue Apr 30, 2019 6:49 pm    Post subject: Reply with quote
Luddite, its closed circuit for normal operation and open circuit when the belt fails.
Jan
9xxnick
PostPosted: Thu May 02, 2019 8:05 am    Post subject: Reply with quote
I wonder if there's any mileage in getting the wheel that rests against the belt remanufactured as a spare. That's the bit that normally fails.
A slight redesign so that the full width of the wheel rests on the belt wouldn't be a bad idea either.
Luddite
PostPosted: Thu May 02, 2019 11:35 am    Post subject: Reply with quote
Jan... Many thanks for taking the time to reply to that which some might think was my seemingly stupid question... (-: Just that logic determines in old fashioned wiring that switch would be configured as a "fail safe" device with a N.O. switch (Normaly Open contacts), the contacts then becoming CLOSED when the wheel is in contact with the belt....the thinking being that if either the switch, the wiring or any connection in the circuit failed at any time... the alarm would be raised.
N.O. or N.C. (normally closed) relates to the switch contact arrangement with the switch at rest.. i.e. in this particular case NOT physically in contact with the belt during testing.
The issue for me was that these days it is possible though perhaps less than "good practice" for digital programming as used in almost everything electrically related, to use either N.O. or N.C. switch contacts to crate some form of positive action like bringing ON an some sort of indicator.
Jan...I guess like others here you may be well aware of all that I have typed and sincere apologies if I come across as pedantic, I am not, though my contribution is hoped to help if someone unsure of electrics beams up your super work on solving the issue...and may be left seeking a little more understanding... Question
Thanks again.
pietrzj
PostPosted: Mon May 06, 2019 8:56 pm    Post subject: Reply with quote
Luddite - its a N.O switch to use your nomenclature. Sorry, I dumbed down my last post - that will teach me.
Luddite
PostPosted: Mon May 06, 2019 11:15 pm    Post subject: Reply with quote
pietrzj, nothing dumb about your well thought out contribution, thanks for taking time to reply.
Old style micro switches can have three terminals and use the I.D. N.O. N.C. and COM Com being short for Common which identifies the terminal which connects to either the N.O. or N.C. dependant on the position of the switch action. I mention this in the off chance that an alternative switch may be used in the assembly should that be all that is available at some future time by someone reading your post..
