997 : 2004- 70
Boxster : 1997- 13
Hamster75
PostPosted: Thu Apr 25, 2019 9:02 pm    Post subject: Rusted Exhaust Bolts Reply with quote
Does anybody know if there's an aftermarket company who sells exhaust bolt replacement kits for 991.1 either in stainless or standard mild steel.
or is it OPC kit needed.
Mine are starting to corrode & I thought I would replace them before they get knackered.
991.1 C2S Red
997.2 C4 White
924 Blue
Thefinn
PostPosted: Thu Apr 25, 2019 9:23 pm    Post subject: Reply with quote
It might be worth dropping these guys a mail as they do them for all of the older models so if the 991 is having the same issue then they might start doing them. They might even be the same size as some of the others already which someone might confirm.
http://www.porschetistuds.co.uk
997.1 C4S CAB
Hamster75
PostPosted: Thu Apr 25, 2019 11:28 pm    Post subject: Reply with quote
Thank you I will give them a call
991.1 C2S Red
997.2 C4 White
924 Blue
kan300
PostPosted: Fri Apr 26, 2019 6:15 am    Post subject: Reply with quote
The rusty exhaust nuts and bolts on my 997 were replaced by the previous owner by OPC under warranty.
Cayman GT4
EX 997.2 4S / Boxster 981 / Boxster 986 / Boxster 718 / 991 Turbo / 991 C2 / Cayman Type R / 997.2 C2 / Cayman
PostPosted: Fri Apr 26, 2019 6:36 am    Post subject: Reply with quote
Don't bother with Titanium, it's just a gimic. Stainless Steel is the way to go.
PostPosted: Fri Apr 26, 2019 6:37 am    Post subject: Reply with quote
Although knowing Porsche, SS will probably void your warranty Grin
Hamster75
PostPosted: Fri Apr 26, 2019 12:02 pm    Post subject: Reply with quote
Thanks Guys,
they are starting to rust & I thought I would change them as I will probably have the car for a few years, I might try the OPC warranty when its in for service in July or just change them myself for original Porsche ones & look after them.
991.1 C2S Red
997.2 C4 White
924 Blue
Rhodris-dad
2015 Porsche 991 Carrera 4 GTS
PostPosted: Fri Apr 26, 2019 12:31 pm    Post subject: Reply with quote
Warranty?.......I paid £600 for my 997 bolts a couple of years back, as exhausts are not covered by a warranty Question
2015 991.1 C4GTS PDK
2010 997 C4S PDK sold
2003 996 C2 Tip sold
mark pearce
Approved Trader
PostPosted: Fri Apr 26, 2019 1:18 pm    Post subject: Reply with quote
is it the exhaust flange fixings that your going to replace?
if so I supply OPC Exeter with stainless steel nuts and bolts,
the nuts are aerotight? lock nuts which have a metal rather than nylon lock washer,
im sure Exeter will sell you a set as I have to buy the nuts with a minimum order of 100
Stirlings The Low Mileage Porsche Specialists
mark@stirlings.co.uk
Tel 01736 757755
www.stirlings.co.uk
Passion for Perfection
Why risk the alternative?
Hamster75
PostPosted: Fri Apr 26, 2019 10:49 pm    Post subject: Reply with quote
Yes it is those
991.1 C2S Red
997.2 C4 White
924 Blue
kan300
PostPosted: Sat Apr 27, 2019 8:38 am    Post subject: Reply with quote
Just checked - exhaust clamps & bolts were changed free on my old 997 under warranty in June 2017 - 26000 miles. This was done by the previous owner.
Cayman GT4
