997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
MarkGolf
PostPosted: Wed Apr 24, 2019 4:16 pm    Post subject: Cayenne 957 GTS/Turbo wishbone different to others? Reply with quote
Can someone help please.
I was about to order a pair of new wishbones for my 2008 957 GTS, somehow I thought to quickly check if the GTS ones were different and it seems the GTS and turbo have a different part number to the rest of the range, along with a note about the brake discs..
Many sites seems to suggest the wishbones are all the same across all models yet a part number site shows different ones for the GTS/Turbo. For the TRW brand, the GTS/Turbo ones do fall cheaper on design911 but I am just interested to know what the difference is.
GTS/Turbo right side 95534101861
All other right side 95534101833
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
PostPosted: Wed Apr 24, 2019 8:02 pm    Post subject: Reply with quote
Ref parts and i'm never really sure .. i use the parts guy at work to be honest ..
i had a look but there are many listed ..
https://www.deroure.com/diagrams.asp?TBL=4677&MAK=3&MDL=34&SMA=0&SMO=0&ST=&SC=0
if it was me .. i would phone an OPC .. say what you want and ask the cost / availability .. they will look it up then tell you the cost .. say thanks and can i you have the part number ..
You then have the part number of the item you want so can use that to find a cheaper alternative .
Indy Mechanic .
MarkGolf
PostPosted: Thu Apr 25, 2019 4:01 pm    Post subject: Reply with quote
Good shout!
Forgot about that site for diagrams too! Thumb Thumb Thumb
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
