997 : 2004- 74
Boxster : 1997- 14
DLec997
PostPosted: Wed Apr 24, 2019 6:14 am    Post subject: Ohlins finally fitted! Reply with quote
So.... After 6 months plus of the shiny Ohlins Road and Track being sat on my for in the office I finally got round to getting them fitted. First impressions are good, need a full setup at Centre Gravity but that's not till next month.
The car had stiffer springs fitted when I purchased the car and it was over sprung and under damped in normal PASM mode. With PASM on it was over sprung and over damped! Now seems better compromise with a noticeably better front end. Still need to play with the settings but currently on 17 front and 15 rear.
My day job is playing with Race cars, I'm technical director and race engineer for G-Drive Racing at Le Mans, the WEC and ELMS in LMP2. I'm doing a road trip to Spa for the WEC next week, then to Monza for the ELMS and home via the Alps...! Will update on where I end up with settings by the end of the trip.
First fitting... Think the front needs lowering a bit more.
 Filesize:  1.36 MB
 Viewed:  911 Time(s)
MaxA
PostPosted: Wed Apr 24, 2019 7:49 am    Post subject: Reply with quote
Interesting. I run Öhlins on the other car, but kept PASM on the 9972 and supplemented it with the TPC Racing DSC controller.
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
DucatiRob
PostPosted: Wed Apr 24, 2019 8:29 pm    Post subject: Re: Ohlins finally fitted! Reply with quote
Had my Ohlins for a few month now and over the moon with the transformation in handling and ride, so much better than the stock PASM, yes a little stiffer at slower speeds but fantastic when you're cracking on a bit Thumb mine were fitted by CG, full geo and corner weighing and would thoroughly recommend them Thumb
Mercedes CLK DD
Ducati 996
DLec997
PostPosted: Thu May 09, 2019 2:53 am    Post subject: Reply with quote
The road trip has been great so far and passed without incident to Spa. Pole position and a new track record in qualifying then crazy weather for the race.... Unfortunately the sudden drop in temp caused a crack in the windscreen of the 997 from a stone chip - this now needs replacing on my return to the UK. Awesome drive down to Monza via Belgium, Germany, France, Switzerland, Italy. Damper settings currently 20 front and 14 rear. Now to plan the return trip 😁.
Spa to Monza in 8hrs
 Filesize:  166.5 KB
 Viewed:  367 Time(s)
Snow in Spa.... 2nd place was just about survival!
 Filesize:  180.61 KB
 Viewed:  367 Time(s)
Marky911
PostPosted: Thu May 09, 2019 4:49 am    Post subject: Reply with quote
Excellent pics. Either of those would make a great full size picture. Cool
Pity about the windscreen. CG will get the best out of your setup when you go.
Cool job by the way. It must be great. Thumb
