997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
acer54
PostPosted: Tue Apr 23, 2019 10:07 am    Post subject: Reversing Camera Reply with quote
According to the build sheet for my Cayenne it was fitted with a factory reversing camera, cut a long story short it doesn't work and I cannot see any evidence that its trying to work.
Where are these factory fitted cameras located? The only place I can see it might be is under a flap just below the tailgate glass hatch lifting mechanism, am I right?
I've never seen one of these camera's on all the Cayennes I've looked at, I assume it should show the image on the PCM screen but as I've said absolutely nothing is seen there.
Slayer
PostPosted: Tue Apr 23, 2019 6:09 pm    Post subject: Reply with quote
I am unsure about cayenne. The only Porsche I owned with a camera is my Cayman. It's near the number plate area like a black nipple and is non retractable. May be its the same for yours and may be covered with dirt not giving a picture
Current: 981 Cayman S with some goodies
Sold:
Golf R 7.5 FL ( Atlantic blue with Akropovic exhausts/ Performance pack)
Golf R FL 7.5, A45 AMG FL, Golf R , Golf GT, VW Golf R (Reflex silver) 2016
VW Golf R, Golf Match, VW Scirocco 2TDI R line-BMT , 997 Gen 1 Turbo , 997 C2S(Aerokit), 997 C2S, Cayman S, 997 C4S, 997 Carrera, Boxster
PostPosted: Tue Apr 23, 2019 6:34 pm    Post subject: Reply with quote
Can you do me a favour please young man .. put what Cayenne you have in a signature please .. im sure you have already told me or mentioned it but i have a memory like a sieve !!
Depending on the year its in a couple of places .. images below .
If you have that flap under the tailgate glass then its fitted but not working ..
For me i would start with a vehicle hand over using a tester before getting more involved .
Indy Mechanic .
 Filesize:  25.44 KB
 Viewed:  2257 Time(s)
 Filesize:  37.61 KB
acer54
PostPosted: Wed Apr 24, 2019 10:22 am    Post subject: Reply with quote
I've updated my signature, it's a 2005 model.
The PCM was changed for a second hand one before my ownership, does the PCM need coding for the camera to work?
2005 Porsche Cayenne V6 3.2 Litre
PostPosted: Wed Apr 24, 2019 8:16 pm    Post subject: Reply with quote
Whist i cant be 100 % sure i would have to say yes .. if the pcm doesnt know its got a reverse camera fitted then it wont activate it .
It can be anything from the camera to wiring to software though .
By knowing i mean it has to be coded as it has one .
Early reverse cameras were not a common option .
Signature .. Thumb
Trust me .. it helps a lot with 4 gens of Cayennes out there Smile
Indy Mechanic .
acer54
PostPosted: Thu Apr 25, 2019 11:05 am    Post subject: Reply with quote
[quote="deMort"]Whist i cant be 100 % sure i would have to say yes .. if the pcm doesnt know its got a reverse camera fitted then it wont activate it./quote]
It's in on the 21st May, I'll have the PCM checked then and if needed have it coded.
acer54
PostPosted: Thu May 23, 2019 9:13 am    Post subject: Reply with quote
PCM coded and now camera working - Result!
