996 : 1997-2005 29
Boxster : 1997- 14
Swampy
PostPosted: Mon Apr 22, 2019 1:58 pm    Post subject: Drain Plugs Reply with quote
Afternoon all, after giving my car a wash this morning I decided to have a look for the 2 drain plugs that members have mentioned that need cleaning out, situated by the battery was mentioned... Could I find them Dont know
Has anyone got a picture or a diagram of these said plugs as I would like to check that they are not blocked thumbsup
Swamps Smile
Swamped By Swampy Smile
Tobyone
PostPosted: Mon Apr 22, 2019 2:54 pm    Post subject: Re: Drain Plugs Reply with quote
Swamps Smile
I have not got a picture but they are either side of the battery and around 20mm diameter black rubber grommet looking things.
You need to take the battery cover off and the covers off either side of that.
Should be pretty obvious then.
I blew mine clear with the hose pipe
997.1 C4s GT Silver, factory Aerokit
TonyC911
PostPosted: Mon Apr 22, 2019 2:57 pm    Post subject: Reply with quote
These should help Swamps Smile
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
 Filesize:  204.83 KB
 Viewed:  626 Time(s)
 Filesize:  186.61 KB
 Viewed:  626 Time(s)
 Filesize:  220.69 KB
 Viewed:  632 Time(s)
Swampy
PostPosted: Mon Apr 22, 2019 7:21 pm    Post subject: Reply with quote
Many Thanks Tonyc911, just what I was after, I have seen these before but wasn't sure where, I shall keep a copy for future ref Smile
Swamps Smile
PostPosted: Mon Apr 22, 2019 7:38 pm    Post subject: Reply with quote
The grommets are there to stop rodents entering that area .. they don't do that job very well i'm afraid .
They tend to block up with leaves and debris from trees ..
You can blow through them .. x2 each side of the battery or the unofficial fix .. push them out .. they will drop onto the fuel tank and disappear down the road leaving a much larger hole that will never block.
If they do block they will fill that area with water which will then enter the pollen filter and cause a wet carpet .. o/s and they will allow water to get into the grommet in the bulkhead there .
Up To you if you push them out or blow them out .
Images above show the very early type .. so upto 2000 model year with drain tubes .. after that it was just a single grommet ( 996 type ).
Swampy
PostPosted: Mon Apr 22, 2019 11:06 pm    Post subject: Reply with quote
Thanks DeMort, I did find one hole, right hand side of the battery (N/S) about the size of a 10p bit, I discounted that as I was expecting to see a grommet but it may of been pushed out as you mentioned above, looks as if that was one of them but I have a better idea where to look now Smile
Thanks to you all Thumb
Swamps Smile
