Posted: Sat Apr 20, 2019 11:16 am Post subject: Headlight Washer Pump advice needed
The headlight washer pump on the 993 has died. I've removed the pump and tested it, its definitely dead.
I've looked up the Bosch part number and its been discontinued.
It seems the replacement pump fits many vehicles, Skoda, VW, Audi also the 996. I went to GSF and was going to buy the pump, however the connector looks different and the outlook pipe is slightly larger. I don't think the plug from the loom will fit in socket in the pump. The spade connectors are smaller in the pump and the plastic surround is longer, so the plug will not fit.
I will order the kit, which is a shame as I wanted to fit it this weekend.
Mike _________________ Mike
993 C4
1973 911T
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum You cannot post calendar events in this forum
