997 : 2004- 74
Boxster : 1997- 14
Hertsdriver
PostPosted: Fri Apr 19, 2019 10:23 am    Post subject: 997.1 3.6 multifunction wheel swap? Reply with quote
Hi all, am looking at a very nice 3.6 but it has the ford mondeo looking big triangle multi function wheel. Is a swap to a sports wheel from an 's' model a simple swap? do you just lose the multi function ability from the wheel or do you have to install something to fool the system into thinking its still attached and not give a warning error? I did search but could find anything specific to this particular swap.
thanks Smile
2018 Brompton S6
2014 Seat Leon FR SC 184
1989 Lancia Delta Integrale 16v
1980 Barlotti BB 210 Upton Villiers 4 speed
1963 Lambretta Smile
villaman
PostPosted: Fri Apr 19, 2019 1:33 pm    Post subject: Re: 997.1 3.6 multifunction wheel swap? Reply with quote
thanks Smile
I put a Sport Desgin steering wheel on my old Boxster 987and had to have the horn recoded using PIWIS as it would'nt work.
Ive put a gen2 wheel on my 997 (it had the same pants "Mondeo" wheel as yours)..and this was a simple replacment...no coding.
The actual removal and is very easy....you will need a TORX bit which i think is 55
986 Boxster S Speed Yellow
987 Boxster Artic Silver
987 Boxster S Basalt Black / Red Roof
997 911 C2S Basalt Black (Current)
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Mon Apr 22, 2019 8:04 am    Post subject: Reply with quote
Triangle (std gen 1) airbag wheel to sport (round airbag gen 1 & 2) is an easy swap, but you will loose the mfsw.
Plenty of directions here. Just be sure to leave keys in position 1 when you remove the battery.
If you want to retain mfsw functions, there is a gen 2 version. Suspect that will need coding for horn and maybe new steering wheel module.
