991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu Apr 18, 2019 8:31 pm    Post subject: Speedometer swap, where is the mileage stored? Reply with quote
I am doing work on the speedometer for my 996 project car. The car is in pieces and will be for ages, so I want to test my electronics by fitting the C4 instruments to my C2. My C2 is on 61k miles, the C4 on 192k.
Am I right in thinking that the mileage is stored independantly in the ECU and Instruments, so if I swap them then any miles clocked up will show as a difference when swapped back? I don't mind that so much as distances will be negligible. What I don't want is for my C2 to think it is on 192k when I swap the instruments back. TBH I don't see how it can with knowing the connections between the ECU and Instruments, but thought it best to see if anybody else has insights from previous instrument swaps.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Thu Apr 18, 2019 11:20 pm    Post subject: Reply with quote
The ECU only shows total hours run so it'll just add more time to the clock.
I'm unsure if the ECU will see the clock swap and throw a paddy though but you may have to calibrate the fuel sender/gauge as the two tanks are different?
MisterCorn
PostPosted: Thu Apr 18, 2019 11:23 pm    Post subject: Reply with quote
Not so fussed about fuel tank. I'll do a few miles. It is a simple voltage from tank to instuments.
IanG1
PostPosted: Fri Apr 19, 2019 10:19 am    Post subject: Reply with quote
Miles/km is stored on the instrument, only hours run and average speed is stored on the ecu. Simple calculation to ascertain if a car has been clocked I used when viewing cars to buy when I hooked up durametric for over revs and faults etc
1998 996.1 C2 manual/LSD with aero and a big smile
