997 : 2004- 74
Boxster : 1997- 14
jockmog
PostPosted: Thu Apr 18, 2019 12:48 pm    Post subject: Unidentified Fluid leak Reply with quote
When I moved my car today I noticed several drops of an almost "luminous" green, slightly oily fluid on the garage floor. It appears to have come from forward of the engine/transmission Any suggestion as to what this might be?
I don't think that it is coolant - it didn't pass the taste test! Confused
rdodger
PostPosted: Thu Apr 18, 2019 12:53 pm    Post subject: Reply with quote
AC dye?
jockmog
PostPosted: Thu Apr 18, 2019 12:56 pm    Post subject: Reply with quote
Thanks, I am leaning in that direction.
PostPosted: Thu Apr 18, 2019 7:23 pm    Post subject: Reply with quote
luminous green is a/c dye .. probably o/s/r just in front of the wheel .
dark green is pentosin which is the power steering fluid .
If you have the old green antifreeze then that's green but often it just looks like water when on the ground so i doubt its that .
Post here about a/c ..
http://911uk.com/viewtopic.php?t=132496
Scroll down to the pipes picture and the big black / red arrow for the location .
jockmog
PostPosted: Fri Apr 19, 2019 8:21 am    Post subject: Reply with quote
Thanks deMort. OPC installed a new metal, front to rear AC pipe a few weeks ago, so it could be a leaking union.
Don.
