996 : 1997-2005 29
Boxster : 1997- 14
DucatiRob
PostPosted: Thu Apr 18, 2019 11:37 am    Post subject: Water Pump Replacement - Metal Gasket Reply with quote
Hi all, advice needed Thumb changing my water pump tomorrow, Pierburg item came with a metal gasket that has a rounded ridge pressed into it! Assuming this type of gasket doesn't need any sort of sealant?
Mercedes CLK DD
Ducati 996
PostPosted: Thu Apr 18, 2019 7:14 pm    Post subject: Reply with quote
No sealant young man and it comes with the oil gasket as well which isn't needed .. the separate bit with a couple of tabs holding it in one piece .. you cut this bit off .
Clean up the surface of the engine before fitting .. scotch brite or emery cloth .
DucatiRob
PostPosted: Thu Apr 18, 2019 8:48 pm    Post subject: Reply with quote
Cheers deMort Thumb
Hoping this job will be a little easier than the starter cable last week, still bear the scars Sad
Mercedes CLK DD
Ducati 996
kurlykris
PostPosted: Thu Apr 18, 2019 8:58 pm    Post subject: Reply with quote
Cheers deMort Thumb
I changed the waterpump on my Boxster a few months back, it`s really straight forward, just make sure you have a 1/4 inch socket set as some of the bolts are tricky to get to Thumb
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
DucatiRob
PostPosted: Thu Apr 18, 2019 9:17 pm    Post subject: Reply with quote
Yes, 1/4 inch socket set to hand Thumb Learned the hard way, nothing is easy to get ay on these cars!
Mercedes CLK DD
Ducati 996
chowgar
PostPosted: Fri Apr 19, 2019 9:07 am    Post subject: Reply with quote
It must be the season for water pumps to fail. Mine packed up a few days ago on the way home from work. I started to hear the tell tale, rumbling sound coming from the rear of the car and once in the garage, the engine relieved itself of a litre of coolant. Weirdly, that's all the coolant that came out and it just stopped dead after that. I was also surprised at how clean the coolant was, but I did replace it a couple of years ago.
I too have ordered all the parts including; Pierburg water pump and gasket, Coolant and a ribbed belt, just in case the old one was damaged. I'll be driving it in to my Indy next Saturday to have the work done. If, however this is the original water pump that failed, its done bloody well for 96K miles!
PostPosted: Fri Apr 19, 2019 9:12 am    Post subject: Reply with quote
Mine packed up recently too,
DucatiRob
PostPosted: Sat Apr 20, 2019 6:03 pm    Post subject: Reply with quote
That's good going to last 96k, mine was at 80k, maybe had a few k more left in it, but with a few Euro trips planned didn't want to risk it! Pig of a job to replace without taking the rear engine bracket off completely so well worth getting an Indy to do it Thumb
Mercedes CLK DD
Ducati 996
