991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
turv996
PostPosted: Thu Apr 18, 2019 7:12 am    Post subject: PSE flexi section cracked - repairable? Reply with quote
Hi All,
My 997.1 has just failed its MOT on emissions - its a PSE - and I've found cracks in one of the flexi sections between cat and back box. Does anyone know if this is repairable? The rest of the exhaust seems in reasonable nick so I don't want to scrap it if it can be avoided.
Cheers, Mark
Cannop
PostPosted: Thu Apr 18, 2019 6:43 pm    Post subject: Reply with quote
The best repair is to grind the old flexi section off completely and get a new section welded in. My car only just squeaked through the MOT emissions last June and the reason was the same as yours, a cracked flexi joint. However as the seams on the boxes were also starting to go I replaced them both last month.
PostPosted: Thu Apr 18, 2019 6:59 pm    Post subject: Reply with quote
I have herd of garages welding on a new flexi pipe .. not sure where you are but a quick search returned this ..
https://mobileweld.co.uk/
You could always ask your local garage .. sourcing the part is probably the hardest part of the job .
Downside to cracks .. it draws air in which can upset the post cat lambdas and will upset the emission tester at mot time .
villaman
PostPosted: Sat Apr 20, 2019 9:00 pm    Post subject: Reply with quote
Interestingly both my flexi hoses or pipes need to be replaced and one on the driver's side is particularly fat and blowing.
My local garage is quoting me £350 to replace... this sounds excessively expensive?
986 Boxster S Speed Yellow
987 Boxster Artic Silver
987 Boxster S Basalt Black / Red Roof
997 911 C2S Basalt Black (Current)
Cannop
PostPosted: Sun Apr 21, 2019 1:56 pm    Post subject: Reply with quote
A lot cheaper than replacing the actual boxes.
Full fat Hartech'd C2S Manual
TonyC911
PostPosted: Sun Apr 21, 2019 2:27 pm    Post subject: Reply with quote
This guy is based in Bedford and has lots of experience with the 997, why not have the Gundo Hack fitted at the same time Thumb
https://www.exhaustmods.co.uk/porsche-911-996-977
2012 Carrera S - Agate Grey / Pebble
Ex 2007 Carrerra S
Ex 2005 Boxster S
Ex 2003 Boxster 2.7
Ex 1998 Boxster 2.5
villaman
PostPosted: Mon Apr 22, 2019 9:05 pm    Post subject: Reply with quote
turv996
PostPosted: Tue Apr 23, 2019 7:28 pm    Post subject: Reply with quote
Thanks for all the comments/suggestions. Frustratingly, I've been unable to get PCW / exhaustmods.co.uk to reply to numerous messages so am having to investigate a plan b. Any other suggestions of suitable companies in Beds/Northants gratefully received!
PostPosted: Tue Apr 23, 2019 8:44 pm    Post subject: Reply with quote
DW Performance in Wellingborough Thumb
villaman
PostPosted: Wed Apr 24, 2019 6:49 pm    Post subject: Reply with quote
Your local Powerflo franchise will im sure sort this...mine has , or will, shortly fix mine for less than half the price a Porsche Indy quoted me
