991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
BillCoupe98
PostPosted: Fri Apr 19, 2019 5:00 pm    Post subject: Reply with quote
Drivers side
BillCoupe98
PostPosted: Fri Apr 19, 2019 5:02 pm    Post subject: Reply with quote
Finished all 12 holes ready for SS bolts Thumb
 Filesize:  1.64 MB
 Viewed:  875 Time(s)
Paynewright
PostPosted: Fri Apr 19, 2019 5:18 pm    Post subject: Reply with quote
Well done in double quick time too!
Ian
BillCoupe98
PostPosted: Fri Apr 19, 2019 5:32 pm    Post subject: Reply with quote
Thanks Ian, I just need to sort out the oil leak from the plug tubes easy whilst the exhaust and bumper are off and then next week when the new parts arrive i’ll Put it together, might even have time for some DIY that I promised the wife I would do whilst on holiday
Glasgow 911SC
PostPosted: Fri Apr 19, 2019 6:14 pm    Post subject: Reply with quote
I thought (most probably wrong) that SS studs on an alu head was a bad idea due to galvanic corrosion, negating the SS advantage over standard studs/bolts. Doesn't someone on here produce affordable (as much as they can be) titanium versions?
1982 Porsche 911SC
1997 Porsche Boxster
PostPosted: Fri Apr 19, 2019 6:35 pm    Post subject: Reply with quote
Have you not read the previous comments in this thread. Titanium is worse than Stainless with regards to attacking Aluminium.
Glasgow 911SC
PostPosted: Fri Apr 19, 2019 6:42 pm    Post subject: Reply with quote
Hands-up. I didn't read the whole thread. 17 years on the forum and 42 posts for a reason Smile
SS is still better than standard ones then?
1982 Porsche 911SC
PostPosted: Fri Apr 19, 2019 6:43 pm    Post subject: Reply with quote
Yes deffo. My SS ones have been in for other 4 years and wound out easy as anything last month.
Glasgow 911SC
PostPosted: Fri Apr 19, 2019 6:45 pm    Post subject: Reply with quote
thumbsup
1982 Porsche 911SC
BillCoupe98
PostPosted: Fri Apr 19, 2019 7:38 pm    Post subject: Reply with quote
The bolts corrode where they go through the exhaust manifold an gasket, on the Porsche OEM manifold it’s a mild steel and stainless sandwich which itself corrodes around the mounting holes and makes the bolts rust just under the head, hence why the steel ones shear off.
The other issue is the bolt heads disappear over time so you round them off when you put a socket.
The only advantage is that steel is easier to drill out than stainless or titanium
jond58
PostPosted: Sat Apr 20, 2019 9:27 am    Post subject: Reply with quote
I’ll be tackling mine this year! With dread!! I’m planning on using an induction tool but thinking I’ll need to drill also, can you hire the jig? Also, regarding bolts I was planning studs and brass nuts which I’ve used lots of times, admittedly on motorcycles, is this not recommended for these?
Paynewright
PostPosted: Sat Apr 20, 2019 12:38 pm    Post subject: Reply with quote
Once the task is complete the jig is probably surplus to requirements Wink
wasz
1999 Porsche 996 Carrera 2
PostPosted: Sun Apr 21, 2019 8:46 pm    Post subject: Reply with quote
I have also been keeping my eyes open for one for a while now, so if you do sell I'd be interested
Paynewright
PostPosted: Sun Apr 21, 2019 8:55 pm    Post subject: Reply with quote
Was hinting OP might be open to offers! Mine will be a while before its available.
Ian
Goto page Previous  1, 2
Page 2 of 2
