996 : 1997-2005 29
Boxster : 1997- 14
Donstanley
PostPosted: Wed Apr 17, 2019 4:50 pm    Post subject: Juddering wipers, worse with wet screen - 997.1 Reply with quote
Hi
For some time I have been trying to cure juddering wipers.
I bought some PIAA wipers and followed the instructions for cleaning and preparing the screen, but they juddered as much as the ones removed.
I then bought some Bosch wipers and cleaned the screen with Brillo, thoroughly washed and dried it and applied Rain X, these do not judder on a dry screen, but do judder on a wet screen. Speed of driving has very little effect.
If anyone has any suggestions it would be much appreciated. I took videos with my iPad of the wipers working on a dry and then a wet screen, but have not succeeded In uploading them With this post.
PostPosted: Wed Apr 17, 2019 6:37 pm    Post subject: Reply with quote
Video to here please ..
De.Mort@virginmedia.com
I'll see if i can upload it .
Fault is a little strange .. i normally replace the blades with Bosch to stop juddering .
It's also not a fault i've seen before on a 997 .. on a Cayenne and we adjust something called the angle of attack .. the angle of the wiper arm basically .
for it to be something like this would make me think of windscreen replacement .. have they been removed and bent .
I'm also wondering if there is a problem with the wiper linkage .. dry joint perhaps .. Dont know
I'm afraid i don't have an answer but i'll look at the video .. this might be a job for a garage to have a look at as something is obviously not right there .
Alfaian
PostPosted: Wed Apr 17, 2019 6:43 pm    Post subject: Reply with quote
Silly question but, have you got the curved wiper for the near side?
Arctic silver C2S
Donstanley
PostPosted: Wed Apr 17, 2019 6:58 pm    Post subject: Juddering wipers Reply with quote
Hi
I think so as they were specifically for the 997 and they are both in contact with the screen for their entire length.
PostPosted: Wed Apr 17, 2019 7:25 pm    Post subject: Reply with quote
Video here ..
https://youtu.be/96Z0WbfcVB0
i'm not sure that's juddering as such but not a clean sweep .. you have streaks as best as i can tell ..
I would start with glass cleaner on the screen .. after that i'm thinking the angle of the arms ... it's hard to be more precise im afraid .. i would need to actually see the car and feel if the arms are sticking .. or indeed see if they are not lined up correctly .
I would assume your local garage could do the same as me .
bobi61
PostPosted: Wed Apr 17, 2019 7:36 pm    Post subject: Reply with quote
I have same problem ,,,just changed to Bosch they look different but not rained since ive changed so cant really tell,,
jl-c
PostPosted: Wed Apr 17, 2019 8:17 pm    Post subject: Reply with quote
this may or may not be of any help?
wipers.pdf
Download
 Filename:  wipers.pdf
 Filesize:  97.62 KB
 Downloaded:  67 Time(s)
Cannop
PostPosted: Thu Apr 18, 2019 6:27 pm    Post subject: Reply with quote
I had the same problem with mine, tried various makes of blades with no improvement. Ended up changing the windscreen and fitting OEM wipers, that sorted it out!
PostPosted: Thu Apr 18, 2019 6:45 pm    Post subject: Reply with quote
Spot on .. that's the attack angle .. i've only ever seen instructions for a Cayenne to date though .
i will say it's probably an OPC job as i know for sure we don't have that equipment and i doubt any indy does .
Chris_in_the_UK
Estoril
PostPosted: Thu Apr 18, 2019 7:38 pm    Post subject: Reply with quote
You can visually check the angle of attack.
Take the wiper blade off and gently put the arm against the glass - the flat should sit flush to the screen. If it's off then get a small adjustable spanner and gently twist it so it sits flush to the screen surface.
2006 Cayman S PCCB's
Donstanley
PostPosted: Fri Apr 19, 2019 4:54 pm    Post subject: Juddering wipers 997.1 Reply with quote
Many thanks for all your suggestions.
Checked the angle of attack, passenger side was correct, but drivers side needed quite a lot of adjustment so the flat of the arm was parallel with the screen, but unfortunately the judder was no better.
Cleaned screen again with Brillo and then with vinegar which was a tip from a 996 thread, and then with glass cleaner, but no improvement.
There is no judder or noise when the screen is dry, but when sprayed with water judder and noise returns, the more the water the more the judder. Judder and noise reduce if no more water sprayed onto screen as wipers dry the screen.
I will try new Porsche wipers and if still no good it must be the screen or the mechanism/motor. Will take it to my Indie for their opinion.
jl-c
PostPosted: Fri Apr 19, 2019 6:46 pm    Post subject: Reply with quote
sounds to me that the arm is not holding the blade firmly and the blade is 'rattling' in the arm. Just a guess?
Johnd52
2011 Porsche Cayman 987
PostPosted: Fri Apr 19, 2019 8:48 pm    Post subject: Reply with quote
Agreed. I would check to see if the arm is correctly mounted on its splines and held securely. The fact that the angle was all wrong makes me suspicious of something more basic.
2015 Cayman GTS. No more PDK but still red.
Donstanley
PostPosted: Sat Apr 27, 2019 7:16 pm    Post subject: Juddering wipers Reply with quote
Thanks for all the suggestions. Fitted Porsch wipers, £34.60 with 10% discount, look exactly the same as the Bosch wipers removed, except with no brand markings.
No judder with wet or dry screen, hopefully will stay like this for sometime.
patpending
PostPosted: Sat Apr 27, 2019 7:18 pm    Post subject: Reply with quote
It’s nearly always down to a faulty wiper motor and not just Porsche specific.
After a short time the fault will usually return.
Had this on a few cars and the wiper blade replacement ended up being a bandaid.
Donstanley
PostPosted: Sun Apr 28, 2019 6:56 pm    Post subject: Juddering wipers Reply with quote
Is there any way to test the wiper motor?
