johnt993997
Well-known member
- Joined
- 13 Jan 2019
- Messages
- 49
Hi there
I'm trying to remove my rear wiper arm from the shaft which comes through the window hole from the motor.
I've undone the 13mm nut, and from what I can see online and in the drawing attached the arm should then just come off. However its not budging. Applied a reasonable amount of force but before I give it a real heave ho, has anyone else done this?
I'm not missing something am I? It's not threaded, and it winds off perhaps? There is a small amount of rust visible so it might be just a bit corroded on.
Cheers for any help!
J
J
