Boxster : 1997- 20
johnt993997
Location: Hertfordshire / Buckinghamshire border nr. Aylesbury / Hemel Hempstead
PostPosted: Tue Apr 16, 2019 9:48 pm    Post subject: HELP PLEASE! removing rear wiper arm, stuck! Reply with quote
Hi there
I'm trying to remove my rear wiper arm from the shaft which comes through the window hole from the motor.
I've undone the 13mm nut, and from what I can see online and in the drawing attached the arm should then just come off. However its not budging. Applied a reasonable amount of force but before I give it a real heave ho, has anyone else done this?
I'm not missing something am I? It's not threaded, and it winds off perhaps? There is a small amount of rust visible so it might be just a bit corroded on.
Cheers for any help!
J
997.1 C2S #blackandgold (hartech'd)
E46 M3 manual coupe
Lotus Exige
Porsche 993 c2 manual coupe (should never have sold!)
AMG E55 (W210) // BMW E46 330i touring // BMW E36 328i touring (first propper car!) // Various dull cars before!
Assembly
 Filesize:  30.58 KB
 Viewed:  716 Time(s)
Wiper arm
 Filesize:  1.84 MB
 Viewed:  716 Time(s)
monster
PostPosted: Wed Apr 17, 2019 12:06 am    Post subject: Reply with quote
I had the same problem a number years ago when trying to remove mine.
You are right, it should just pull off, but its on a taper and needs a bit of encouragement.
I purchased one of these and it did the job nicely!
https://www.ebay.co.uk/itm/161588114024?ul_noapp=true
johnt993997
PostPosted: Wed Apr 17, 2019 6:40 am    Post subject: Reply with quote
Cheers Monster, wow there's even a tool for it!
Tapered, that makes sense now.
Ta.
E46 M3 manual coupe
Lotus Exige
PostPosted: Wed Apr 17, 2019 7:00 pm    Post subject: Reply with quote
There is a tool for removing wiper arms .. i have one but for these it shouldn't really be needed ..
Angle the wiper arm up at 90 degrees to the base then rock side to side .. they normally come off this way ..
Or lets just say they do for me and i use the tool on Cayennes mainly .
Always .. and i mean always .. when the tension is gone and its loose .. cover the end with your hand so it cant snap back into place .. it will damage the screen if it shoots back to straight position and close the the screen .
