Boxster : 1997- 14
Cayenne : 2003- 3
jimk04
PostPosted: Tue Apr 16, 2019 6:46 pm    Post subject: Gt3/turbo 6 pots...plus associated parts Reply with quote
Hello all.
I know I dont frequent this forum....so initially apologies for using it as a selling platform for this thread.
Just removed from my track biased boxster.
I have for sale a pair of very nice and serviceable 6 pot calipers.....in factory red. Came off a late 997.1 gt3 steel. Small lug spacing as per most steel brakes 350mm....not the wider lugs as on 380mm steel Cup and later PCCB style fitment .
In veet good condition but by no means mint. Perfectly good to go mechanically. They were rebuilt with new dust and fluid seals 3 years ago. All BAR ONE zirconia ceramic piston caps are all present and perfect. One of the 28mm caps was damaged so the piston was replaced with a new non ceramic topped piston.
Sale to include new unused Yperion titanium pad heat shims.
Set of as good as new TRW pads
Set of as good as new cheapo pads
Set of part worn Pagid RS19.....loads of life left
The hard brake lines from calipers to the flex is
The pad fitting gubbins
Not included the caliper fixing bolts. I have Cup car studs so they remain in my uprights.
Bleed ripples are good and free....cracked off this weekend.
Asking £1500 for the lot
Pics up soon
I am a long time Rennlist member and have done many international sales of fairly high value....all under my login name as seen here . jimk04.
Please have confidence .
Regards and pictures up soon.
Track focused 986S
ragpicker
Estoril
PostPosted: Tue Apr 16, 2019 6:53 pm    Post subject: Reply with quote
So will these fit on the standard 986 boxster hub carrier without an adaptor?
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Apr 16, 2019 7:38 pm    Post subject: Reply with quote
No, small lug spacing is relative. Assuming these are the same as a 996 GT3 they will fit turbo or GT3 uprights.
jimk04
PostPosted: Tue Apr 16, 2019 9:23 pm    Post subject: Reply with quote
I have 997S uprights so you'd need something similar to fit to any small brake car
Track focused 986S
PostPosted: Tue Apr 16, 2019 9:28 pm    Post subject: Reply with quote
Happy to vouch for the OP Thumb
jimk04
PostPosted: Tue Apr 16, 2019 9:44 pm    Post subject: Reply with quote
Track focused 986S
jimk04
PostPosted: Tue Apr 16, 2019 9:53 pm    Post subject: Reply with quote
Cheers Jin!
Track focused 986S
jimk04
PostPosted: Tue Apr 16, 2019 9:55 pm    Post subject: Reply with quote
And I forgot to mention. The outer pad support pins have been machined down bya couple millimetres to allow use of Cayenne discs
Track focused 986S
Slippydiff
PostPosted: Wed Apr 17, 2019 9:16 pm    Post subject: Reply with quote
Bargain, the calipers are £1800 each now IIRC.
uk996
PostPosted: Thu Apr 18, 2019 3:58 pm    Post subject: Reply with quote
New are £1711 a pair incl VAT.
Used to be under £1000 a pair, then Porsche in their wisdom put the price up.
2002 996tt Aero in seal grey 6MT
jimk04
PostPosted: Fri Apr 19, 2019 11:02 am    Post subject: Reply with quote
I thought they were about a grand each plus vat so maybe I am pitching a little high. In which case I will listen to sensible offers
Track focused 986S
Slippydiff
PostPosted: Sat Apr 20, 2019 7:36 am    Post subject: Reply with quote
Intrigued by where you’re getting your price of £1711 inc vat from ?
FVD list them at £1150 each (I imagine plus VAT and carriage ?) and Carnewal list their complete Mk 2 6 pot upgrade (calipers, discs and pads) package at €3600 plus carriage.
uk996
PostPosted: Sun Apr 21, 2019 1:32 am    Post subject: Reply with quote
PM sent Slippydiff and Jim.
Sorry, not my intention to mess with your sale.
NLW73
PostPosted: Sun Apr 21, 2019 10:55 am    Post subject: Reply with quote
very nice. there must be 4-500 pounds worth of pads there folks!!
I know a set of Pagid 19s for those calipers are about £500 new!!!
they look in VGC and good value.
997 C2s Schwarz
