997 : 2004- 69
Boxster : 1997- 13
Cayman : 2005- 14
PostPosted: Fri Apr 26, 2019 3:54 pm    Post subject: Reply with quote
I watched it again last night and got a better idea of how bad it was:
When Ant was hammering that IMS replacement bearing into the shaft you can see the engine swinging on the engine mounts. The engine obviously wasn't supported very well on the stand (not enough to be belting with a mallet anyway). I dread to think what internal damage he's potentially done nooo
The cab roof rear window was mullered and in desperate need on a new one fitting. Alloy wheel also needed refurbing with chunks missing out of them.
His comment about the bearing feeling like it was full of sand was a blatant lie.
1/4 of a pint of oil comes pouring out the shaft once the bearing was removed, proving that engine oil had been lubricating the bearing.
There was plenty of stuff they should've been spending their $$$$ on instead of promoting some dodgy after-market snake oil fix and wrapping the centre console. All in all a very poor episode packed with lie after lie.
Wonder how long it'll be before the new owner is on rennlist wondering why his engine needs rebuilding. Grin
ursicles
PostPosted: Fri Apr 26, 2019 7:31 pm    Post subject: Reply with quote
They often do random no value stuff to car's.
Think car SOS and the way they restore a car is so much better.
996 X50 Turbo ... Sold
987 2.7 ... Sold
996 C2 ... on the hunt for one
mikeluke
PostPosted: Fri Apr 26, 2019 7:38 pm    Post subject: Reply with quote
Never let facts get in the way of a good TV programme!
Smile
Current:
981 Boxster S PDK
BMW X5 4.0d M Sport
BMW M140i (Mrs L's)
VW Polo Match 1.2 (the lad's)
Former:
996 Turbo S Cabrio Manual
996 Turbo Coupe Tip
968 Cabrio Manual
PostPosted: Fri Apr 26, 2019 10:18 pm    Post subject: Reply with quote
Like a Scouser once said to me - "Never let the truth spoil a good story"
Same bloke - "You can tell a Prick, but you can't tell him much"
rigsby99
PostPosted: Sat Apr 27, 2019 7:41 am    Post subject: Reply with quote
When Ant was hammering that IMS replacement bearing into the shaft you can see the engine swinging on the engine mounts. The engine obviously wasn't supported very well on the stand (not enough to be belting with a mallet anyway). I dread to think what internal damage he's potentially done :nooo:
Wonder how long it'll be before the new owner is on rennlist wondering why his engine needs rebuilding. :grin:
It's a TV show for Gawds sake, not a engineering instructional video. The oil coming out of the bearing aperture is not much use to a sealed bearing.
PostPosted: Sat Apr 27, 2019 7:51 am    Post subject: Reply with quote
Well the bearing obviously wasn't sealed otherwise the oil couldn't have got in there could it.
rigsby99
PostPosted: Sat Apr 27, 2019 8:07 am    Post subject: Reply with quote
All the original bearings were sealed, one of the fixes was to remove the seal and allow the crank case oil to access the bearing.
maldren
PostPosted: Sat Apr 27, 2019 8:10 am    Post subject: Reply with quote
and was a leather covered centre console ever an original option?
Mike
PostPosted: Sat Apr 27, 2019 8:13 am    Post subject: Reply with quote
I know - I removed my seal years ago. It is only a dust shield and over time warps. Once it does, engine oil gets in there to lubricate the bearing. The only way oil can get into the shaft (as seen in the program) is if this has happened.
rigsby99
This was the first time I have seen a bush used as a replacement. Interesting to hear of any experience or feed back on such a fix, Doesn't seem a good idea at all to me.
PostPosted: Sat Apr 27, 2019 8:15 am    Post subject: Reply with quote
Not as I'm aware of. Would've looked far better and more standard to just colour code it Arctic Silver.
PostPosted: Sat Apr 27, 2019 8:21 am    Post subject: Reply with quote
Me neither. It's been talked about in the past. Here's my view on it:
Pros:
Solid stronger bearing that should last as long as the front end ims bearing.
Cons:
Robbing vital oil (pressure) from other engine components.
Risk damaging the oil pipe that's exposed running under the car. Rupturing it would be catastrophic and seize the engine.
Bastardising the flywheel housing and oil filter housing.
Imagine driving your car with a hole in your oil filter allowing oil to escape somewhere else. Fair enough, it ends up back in the sump, but even so - just sounds foolish to me.
rigsby99
PostPosted: Sat Apr 27, 2019 8:22 am    Post subject: Reply with quote
Dust shield ? Where does dust come from? It is there to seal and contain grease within the bearing, when that breaks down the bearing fails. Porsche presumably thought that there would be insufficient lubrication from crank case oil, in practice it seems there is.
rigsby99
PostPosted: Sat Apr 27, 2019 8:26 am    Post subject: Reply with quote
Pros:
Cons:
It won't affect the oil pressure, it's not an open ended pipe and if it did you might notice a red light.
PostPosted: Sat Apr 27, 2019 8:28 am    Post subject: Reply with quote
It is refereed to in the industry as a dust shield. Sealed bearings are designed to be used in an open atmosphere. The shields are there not only to hold grease in but also stop any unwanted particles getting in there.
There you go: http://www.manujaipur.com/dust-shields.php
PostPosted: Sat Apr 27, 2019 8:29 am    Post subject: Reply with quote
It won't affect the overall oil pressure but will affect the pressures required at each individual component (So Hartech tell me - or are they wrong?).
rigsby99
PostPosted: Sat Apr 27, 2019 8:41 am    Post subject: Reply with quote
Indeed as wheel bearings etc ,but not in this application.
rigsby99
PostPosted: Sat Apr 27, 2019 8:48 am    Post subject: Reply with quote
Oh really, so a pressure fed gauge would have the same effect? It obviously depends on where the tapping is. If you wish to quote Hartech then, for their sake, make sure you get the context right.
PostPosted: Sat Apr 27, 2019 8:52 am    Post subject: Reply with quote
So do you think that by fitting a pipe in the side of the oil filter that allows oil to be pumped to the other end of the shaft have zero effect on pressure at (for example) the crank bearings or cam shafts?
rigsby99
PostPosted: Sat Apr 27, 2019 9:04 am    Post subject: Reply with quote
No it wouldn't as long as the bearing, oil cooler, gauge etc didn't leak or, in the case of a bearing was tight enough to maintain the pressure. Worn main bearings will show a drop in oil pressure assuming that the pressure control system cannot compensate.
Goto page Previous  1, 2, 3, 4  Next
Page 3 of 4
