997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 15
k11pol
PostPosted: Sun Apr 14, 2019 5:55 am    Post subject: Speed camera detector Reply with quote
Im after a speed camera detector but was hoping i could get one with a built in dash cam, is there such a thing available ? Ideally a detector that picks up radar and laser both mobile and static.
Anyone have any advice, thanks
Magic919
PostPosted: Sun Apr 14, 2019 6:37 am    Post subject: Reply with quote
I expect the market for speed camera detectors that include a camera to be very small, for obvious reasons.
997.2 C4S PDK
TonyC911
PostPosted: Sun Apr 14, 2019 8:02 am    Post subject: Reply with quote
I was looking at dash cams recently and did rather like the look of this Garmin unit - https://www.amazon.co.uk/dp/B06XN611DT/
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
s2000db
2011 Porsche 997 Turbo S
PostPosted: Sun Apr 14, 2019 10:08 am    Post subject: Reply with quote
Here you go....
https://aguriworld.co.uk/product-category/dash-cams/
Lambo Huracan Performante
997 TurboS
997 C2S
996 C4
k11pol
PostPosted: Sun Apr 14, 2019 10:36 am    Post subject: Reply with quote
So is the Aguri something you have yourself ? I was recommended the Aguri over the snooper but wanted to hear some different opinions.
s2000db
PostPosted: Sun Apr 14, 2019 1:58 pm    Post subject: Reply with quote
I’ve just got the standard detector without dashcam, works very well aside from the alerts aren’t directional.
997 TurboS
997 C2S
996 C4
Sy
PostPosted: Sun Apr 14, 2019 2:46 pm    Post subject: Reply with quote
Waze app on your phone and dash cam app mounted on the dashboard facing out the window would be low cost option. Waze works really well at crowd sourcing info on speed camera’s and mobile cameras. Not tried a dash cam app yet though.
He who dies with the most toys wins!
Jake911
PostPosted: Sun Apr 14, 2019 2:51 pm    Post subject: Reply with quote
I use the 65w version and its brilliant Thumb also very small and discrete when fitted.
The return of Marty Wild
PostPosted: Sun Apr 14, 2019 3:48 pm    Post subject: Reply with quote
Waze is king.
Cayman S 987.1
Bikeracer1098
PostPosted: Sun Apr 14, 2019 8:22 pm    Post subject: Reply with quote
Waze & Laser jammer
997.2 turbo
Stillen Supercharged Nissan Nismo
Aprilia RSV4 RF
k11pol
PostPosted: Mon Apr 15, 2019 2:19 am    Post subject: Reply with quote
I have and use Waze which is good but twice in the past fortnight i have passed a mobile van and then car with the gun pointing at me with no warning. Im after something that detects opposed to dependent on someone alerting the app.
rickprice
PostPosted: Mon Apr 15, 2019 11:10 am    Post subject: Reply with quote
Surely by the time the laser has hit you it’s too late?
k11pol
PostPosted: Mon Apr 15, 2019 11:30 am    Post subject: Reply with quote
That’s the reason for the detector so you get a warning before it has time to detect your speed.
Sy
PostPosted: Mon Apr 15, 2019 11:32 am    Post subject: Reply with quote
I used to have a laser/radar detector and it gave loads of false alarms so was pointless and stopped using it, although that was a while ago, so tech might have marched forward a bit.
Yes true @Rickprice if the laser detector goes off you are fu*ked anyway, that’s why you would need a jammer, but who knows if they work, lots of mixed reviews on them. Plus, unless you are attempting a Cannonball run then I don’t see the point really.
If you had a ton of points on your licence then I guess it’s probably worth investing in a few to try them out, but I’ve found Waze to be pretty bloody good at detecting cameras so far, and best policy is to be on your guard and look to the vanishing point at all times and don’t drive like a complete bell end and so far outside of the law that you can’t scrub off speed in time.
Sy
PostPosted: Mon Apr 15, 2019 11:42 am    Post subject: Reply with quote
Have you ever used one before? I had one when I was younger and dumber and drove like a tit.
They don’t give you much time to react, or mine never did. Plus you don’t get any time from a laser, once they get you it’s over, that’s why you get laser jammers so they have to hit you a few times and gives you time to slow down. The radar ones you have a bit more time since they give off signals the device is able to pick up a bit further down the road, with laser it didn’t give off any signals till they have pulled the trigger on you.
Might have all changed since the last time I used them, so I’m happy to be corrected based on modern tech since my reference point was a few years back.
chicb
PostPosted: Mon Apr 15, 2019 12:48 pm    Post subject: Reply with quote
As above, waste of money. Laser does not give a signal until he hits the trigger, then its to late. Only warning it gives is the summons is in the post. Radar picks up signals from everywhere, constantly bleeping so you end up switching it off
s2000db
PostPosted: Mon Apr 15, 2019 2:01 pm    Post subject: Reply with quote
I’d advise against using a jammer, laser speed guns have a warning if they’re being blocked, and you’ll end up with 3 months in the clink for perverting the course of justice. As was reported recently.
997 TurboS
997 C2S
996 C4
