997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 15
Jam911
PostPosted: Sat Apr 13, 2019 6:41 pm    Post subject: 1St DIY Major Service Reply with quote
So I spent 6 hours of today carrying my first DIY Major Service.
I have to report beforehand that I was worried about access to and replacing the spark plugs and also bleeding the brakes.
But I have to say it all went very well, aided by some but not too much swearing and occasionally banging my head on the exhausts.
Access to the plugs was the hardest part by far and without borrowing my mates ramp it would have been impossible. I did not have to remove the silencers as some say but it is very tight to get a socket in let alone a torque wrench or your hands for that matter.
Being able to actually see what you re doing is very hard too.
Removing the coil packs and associated wires was a ***** as was getting them back on/in.
I think it took about an hour and a bit to do the first spark plug and then I got faster and faster, it still took about four hours in total.
One strange thing was that I really struggled getting the first coil pack back into the block, I had to tighten the bolts to get it back in securely. All the other ones pushed back in quite easily. This concerned me so I removed the first coil pack and compared it to one of the others. Upon inspection it had what looked like an adapter on it and none of the others did, so I removed the adapter and it went back in fine. So it looks like it shouldn't have been there in the first place.
Now I wonder if that is why the car would occasionally feel like it had a miss fire / hesitate when holding a gear at about 50/60 mph....
I also replaced the heat shields as they had rotted to bits and once I worked out how that fitted they are a simple fix.
Changing the oil and filter is a simple job too.
Air box takes a bit of messing about to get it out but then the air filter and pollen filter are simple.
The poly belt is surprisingly easy too but I did have a hand on the final part.
When replacing the brake fluid I first sprayed the bleed nipples with freeing oil and left them for a few hours before releasing. I was very nervous about this and I brought stainless steel replacements and I was going to swap them out but in the end I didn't want to push my luck, so I just flushed through with new brake fluid.
Car now runs very smoothly and I am having lots of wine to celebrate.
Also it was fun to work on my own car and very satisfying too.
Plus I saved £1000 on what my local OPC would have charged me to do the work.
Current '07 997 C4S
Ex '99 2.5 Boxster
brownspeed
PostPosted: Sat Apr 13, 2019 6:58 pm    Post subject: Reply with quote
well done that man. cheers!
2004 997.1 C2S (Hartech rebuilt)
2002 TVR Tamora 3.6
1990 Mini Cooper RSP
Abarth 595
PostPosted: Sat Apr 13, 2019 6:59 pm    Post subject: Reply with quote
All in all an excellent job young man .. satisfying isn't it Smile
It's not all about the cost .. it's an achievement Thumb
Trust me .. the more you do and the faster you get .. with practise then a plug change is less than 1 hour but a ramp helps a hell of a lot .
No idea on this adaptor thing though . a picture might shed light on it .. the coils just push over the plug and whilst a little tight don't really give problems .
TonyC911
PostPosted: Sat Apr 13, 2019 7:04 pm    Post subject: Re: 1St DIY Major Service Reply with quote
Great job! thumbsup
When can I book mine in?? Smile
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
sja360
2007 Porsche 997 Carrera 4S
PostPosted: Sun Apr 14, 2019 4:01 pm    Post subject: Reply with quote
Great Job Thumb
Out of interest would you be worried come sale time or are you keeping the car?
Im considering doing the services also DIY but I wondered about the effect of resale if you had to.
Do you regularly get the car checked over by an independent or?
Jam911
PostPosted: Sun Apr 14, 2019 5:36 pm    Post subject: Reply with quote
I did think about not having an OPC full service history but:
1 I intend to keep the car, at the moment.
2 I keep all receipts and any future owner would see that the car is very well
cared for and not skimped on at all.
3 I am probably more careful servicing the car than any OPC would be. IMHO
4 Any specialist work will be at an indy and fully receipted.
5 The car will have over 100k miles on it in the next 12 months and effectively
be worthless ...almost.
6 I intend to drive it as much as possible it has been my daily for 8 years now and I still love it.
Current '07 997 C4S
Ex '99 2.5 Boxster
Chris_in_the_UK
Estoril
PostPosted: Sun Apr 14, 2019 5:39 pm    Post subject: Reply with quote
Nice one!
Do all my own stuff now (pretty much).
As regards re-sale?
It's staying for the foreseeable, but I keep all receipts, take photo's and keep records of everything in a large box file.
Personally, I would rather have an enthusiast kept car with stuff like this as opposed to a few OPC/Indy receipts.
2006 Cayman S PCCB's
rob_p
PostPosted: Sun Apr 14, 2019 7:07 pm    Post subject: Reply with quote
Ive started doing the interim (annual) oil changes myself.
It's dead simple and I resent paying for something so straightforward.
My Indy was quite shocked I had signed the service manual myself.
If someone wants to argue it's worth less when i eventually come to sell it then so be it - but it will have had more regular oil changes than Porsche recommend - that's a quality problem to have!
991.1 C2 (no mods, yet)
Jeep Grand Cherokee WK2
Ex Porsche Boxster 986
Ex Mazda MX5 mk1
PostPosted: Sun Apr 14, 2019 7:10 pm    Post subject: Reply with quote
Official documentation is only any use when people don't know what they're looking at. No offence to Porsche owners, this goes for any consumer product out there.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Sun Apr 14, 2019 8:08 pm    Post subject: Reply with quote
I've done all my own stuff to the car, including fairly major work like clutch and flywheel for 5 years.
They are no harder than any other car to work on, time to bust that myth!
I do my plugs on the deck with wheel removed, reckon I could do them blind fold now Floor
I'll tell you when I sell it if its had any effect on value... Traders prob won't touch it. However it is worth more now than I paid for it anyway....
easternjets
PostPosted: Sun Apr 14, 2019 10:24 pm    Post subject: Reply with quote
Jam911, can I book my car in for a full service and especially the wine and cheese afterwards, or can you be paid in wine instead? Very Happy
If you think the plugs and coils are a ball ache you want to try a gen 1 turbo, the best gynecologist in the land would be stumped, the near side one behind the turbo caused a near full strip down.
Well done for the effort, it's a great feeling to get it all back together and it runs.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
kas750
Reims
2006 Porsche 911
PostPosted: Sun Apr 14, 2019 11:47 pm    Post subject: Reply with quote
I sold my 911 to the first person to actually view and he loved that I had maintained it in recent times myself.
PostPosted: Mon Apr 15, 2019 6:29 am    Post subject: Reply with quote
The fact that most people who harp on about documented service history/OPC/Porsche specialist, etc. usually wouldn't go near a private sale through their own fear sort of debunks their argument.
Jam911
PostPosted: Mon Apr 15, 2019 2:35 pm    Post subject: Reply with quote
Thanks for the supportive comments chaps.
Current '07 997 C4S
Ex '99 2.5 Boxster
KJD
PostPosted: Mon Apr 15, 2019 5:04 pm    Post subject: Reply with quote
Great work there. I wish I was as brave. Thumb
Arctic Silver 997 Manual Carrera 2s
Frenchmeister
2004 Porsche 997 Carrera 2S
PostPosted: Mon Apr 15, 2019 7:51 pm    Post subject: Reply with quote
Same with mine though it did go to a specilaist bi annual for a stamp, changed the oil and filter in between every 12 months sometimes it had not covered a thousand miles, did brakes all round, coil packs heat shields etc.
Treat the car like a baby which would not have been the case elsewhere and would have been rodgered on price.
Plus while I was in there things get cleaned or changed if they look tatty, cavity wax applied to protect where required etc
Painted components such as roll bars get a wipe over with some oil or WD40 to help protect them.
All receipts kept, I do this on all my cars, I have witnessed some main dealer and specilaist horrors, some I would not let near my daughters pushbike nooo
997 Carrera 2S 54 Arctic Silver
944 Turbo S 88 Solid Black
BMW X3 2.0D M Sport 06 Silver Grey
BMW E46 330i touring M Sport 05 Imola Red 2
GMG
PostPosted: Tue Apr 16, 2019 5:58 am    Post subject: Reply with quote
...I do all of the general maintenance and other work...brakes,air con condenser change,suspension, exhaust etc...because I simply don't trust garages to do a good enough job to satisfy me...they don't take their time,charge too much and have no investment other than financial in my car's....
I didn't do the engine rebuild of course Very Happy
Plus our cars are not exactly exotica ! Do your own work if you can,save a ton of money and present prospective buyers with evidence that the car is running right...a good well looked after car will always find a buyer...
2 years between oil changes ffs... Surprised
Wh1t3Kn1ght
2001 Porsche 996 Carrera 2
PostPosted: Tue Apr 16, 2019 11:22 am    Post subject: Reply with quote
Good job that man - feels good to do it yourself right?
And no wondering what the mechanics in the garage did or didn't do Thumb
Current Cars
2000 Violet 911 Carrera 2 3.4
1990 Panther Black 944 Turbo
2013 Mercedes A-Class A220 CDI
Previous Cars
1987 Alpine White 944S
1987 Black 944
PostPosted: Tue Apr 16, 2019 6:28 pm    Post subject: Reply with quote
If you ever wish to do it then i will happily explain every step of the way with you either on here , via email or on the phone young man ..
Its a rewarding experience that also says you money .
Jam911
PostPosted: Tue Apr 16, 2019 6:51 pm    Post subject: Reply with quote
deMort your input and experience was a great help, thank you very much.
Current '07 997 C4S
Ex '99 2.5 Boxster
