997 : 2004- 76
996 : 1997-2005 35
Boxster : 1997- 22
Cayman : 2005- 15
Cayenne : 2003- 3
Jam911
PostPosted: Fri Apr 12, 2019 7:40 am    Post subject: Bleeding Brakes - How Tight Bleed Nipples? Reply with quote
I am replacing my brake fluid tomorrow and would like to know how tight the bleed nipples should be done up?
Current '07 997 C4S
Ex '99 2.5 Boxster
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Apr 12, 2019 7:53 am    Post subject: Reply with quote
8-12Nm on the 996, I doubt the 997 is much different. I must admit I have never used a torque wrench on one.
maldren
PostPosted: Fri Apr 12, 2019 8:07 am    Post subject: Re: Bleeding Brakes - How Tight Bleed Nipples? Reply with quote
The first challenge may well be how tight they are to undo, they corrode. Get some stainless replacements.
Mike
wasz
1999 Porsche 996 Carrera 2
PostPosted: Fri Apr 12, 2019 8:28 am    Post subject: Reply with quote
Tight enough but not too tight.
Best tip for undoing the nipples is to use the T bar from your socket set to apply an even rotating torque to the nipple. Don't swing on a spanner.
If it feels stuck don't just force it, they snap for fun.
ragpicker
Estoril
PostPosted: Fri Apr 12, 2019 8:59 am    Post subject: Reply with quote
They often need heat to loosen them, but be careful as you can scorch the paint on your callipers with the blow torch. Fortunately I've never had one snap using heat but I have had some scorched calliper paint Grin
MisterCorn
PostPosted: Fri Apr 12, 2019 9:09 am    Post subject: Reply with quote
My understanding is that this is the correct torque for all nuts Smile
As mentioned, getting them out might be the hard part.
craig15
PostPosted: Fri Apr 12, 2019 11:42 am    Post subject: Reply with quote
When I'm about to open bleed nipples I repeadly tap them end on with a hammer before attempting to unscrew them. The idea is to break any seal caused by corrosion.
Craig
PostPosted: Fri Apr 12, 2019 7:47 pm    Post subject: Reply with quote
craig15 wrote:
When I'm about to open bleed nipples I repeatedly tap them end on with a hammer before attempting to unscrew them. The idea is to break any seal caused by corrosion.
Craig
That's what i do .. but i use my hand .. i'm afraid after many years doing this its not far off being a hammer on my palm but you get a bit more feeling for it .. you can tell if something is going to come undone basically so you have a choice .
If something is pretty tight but im getting it out regardless then i use a socket / ratchet and a 3/8ths at that ... then i pray .
i just tighten them up .. torque settings are all very well when they are new .. add in some corrosion to the base or the threads and you need a little bit more .. or replace and clean the threads ... new nipples are a pretty good way forward and one i would recommend .
