Boxster : 1997- 25
jezgreen911
PostPosted: Thu Apr 11, 2019 12:26 pm    Post subject: Broken Indicator Stalk Reply with quote
So driving home in the sunshine yesterday and enjoying life .......
Then the indicators start playing up, down for left won't cancel and up for right has to be held up to work, a quick Google search points to a common problem and a sealed unit.......
Just wanted to check that a repair is not possible before I order a new complete four stalk unit?
Cheers Thumb
2003 996 C2
PostPosted: Thu Apr 11, 2019 7:08 pm    Post subject: Reply with quote
Nope .. 4 stalk is the cheapest option ... or at least it used to be unless Porsche have altered their prices .
jezgreen911
PostPosted: Thu Apr 11, 2019 8:19 pm    Post subject: Reply with quote
Thanks deMort Thumb
2003 996 C2
Paynewright
PostPosted: Fri Apr 12, 2019 6:29 am    Post subject: Reply with quote
Slight thread hijack - just been looking at the stalks to check the prices and noticed there are a few different types.
Mine is a 3 stalk (onboard computer). What extra work is involved in fitting the 4 stalk to get cruise? Any extra modules / cables to fit or just a re-program of the brain?
Ian
Steve B
PostPosted: Fri Apr 12, 2019 6:35 am    Post subject: Reply with quote
There's a good write up / guide to retrofitting the 4 stalk unit here:
http://www.911uk.com/viewtopic.php?t=115078&highlight=cruise+retrofit
2003 Cobalt Blue Porsche 996 C4S
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Apr 12, 2019 6:53 am    Post subject: Reply with quote
Ian
Cheap amd easy on e-gas cars, not so on those with a proper throttle cable as I understand it.
Paynewright
PostPosted: Fri Apr 12, 2019 7:56 am    Post subject: Reply with quote
2003 car so if I get a failure worth considering!
Ian
wasz
1999 Porsche 996 Carrera 2
PostPosted: Fri Apr 12, 2019 8:23 am    Post subject: Reply with quote
Ian
With a cable throttle manual car you need the "tempomat" controller (its a servo motor and ecu), throttle pedal with extra actuation cable and a another brake pedal switch to fit to the clutch pedal. You need to make up some cabling between stalk and tempomat and switch, and a wire to the clocks for the light, but AFAIK it does not need any car coding as the system is independant of the ECU. A Tip needs extra wires. There is a guide somewhere on the American websites.
I have collected the bits apart from stalks and wiring to fit to my car but never been bothered. Rarely use it for long motorway drives anymore since we had a baby.
