997 : 2004- 76
996 : 1997-2005 35
Boxster : 1997- 22
Cayman : 2005- 15
Cayenne : 2003- 3
IanG1
PostPosted: Wed Apr 10, 2019 4:27 pm    Post subject: Rear hub toe arm ball joint insert Reply with quote
As those who have followed my woes will know I am changing out my rear hub due to a snapped caliper bolt. Mistercorn is kindly pressing me a new bearing but has told me the insert in the hub where the toe arm ball joint sits is missing. Now can I presume I am ok to remove the insert from my scrap arm and press it in or am I missing something?
MC is waiting on pressing in my new bearing till we know it's ok to do?
Any help appreciated
Ian
1998 996.1 C2 manual/LSD with aero and a big smile
IanG1
PostPosted: Wed Apr 10, 2019 4:36 pm    Post subject: Reply with quote
Pic for reference, the insert doesn't appear on the parts diagram as a separate part but is clearly just pressed into the hub to provide the taper for the ball joint.
 Filesize:  74.93 KB
 Viewed:  1223 Time(s)
PostPosted: Wed Apr 10, 2019 5:21 pm    Post subject: Reply with quote
I'd say you're fine to use your old one.
PostPosted: Wed Apr 10, 2019 7:08 pm    Post subject: Reply with quote
i've seen this a couple of times .. we fitted a new hub each time .
Alex is the engineer .. i'm just a mechanic so i would tend to go with his advise .. in theory when its all bolted up it would work .. but in my trade we cant take that gamble so we replace the unit .
IanG1
PostPosted: Wed Apr 10, 2019 7:22 pm    Post subject: Reply with quote
Thanks for the replies, my feeling was it would be fine as once bolted up it can't really go anywhere. I am presuming the original insert had the ball joint taper siezed in and came out when the joint was split so that tells me they should press out. Understand what you say though demort as a professional repairer you can't risk any liability regardless how small the risk.
PostPosted: Wed Apr 10, 2019 7:26 pm    Post subject: Reply with quote
They press in and come out when stuck on the ball joint .. you can see the splines it would normally lock on in your image.
i would think to refit .. heat hub .. cool the insert .. put it in a fridge then maybe a G clamp try to rejoin the two ... or a press.
Obviously as you have said .. i cant condone this .. my worry is it will start to spin in the hub and wear it away ..
Do i think it will do that .. nope ..
Can i take a chance and recommend this .. nope Smile
I'm afraid what i say here is not really any different than what i say and do at work ... my ass on the line basically ... but i try to suggest things.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Apr 10, 2019 7:35 pm    Post subject: Reply with quote
Bring it along on Friday and we can press it back in.
IanG1
PostPosted: Wed Apr 10, 2019 7:42 pm    Post subject: Reply with quote
Will do pal.
Paynewright
PostPosted: Wed Apr 10, 2019 8:50 pm    Post subject: Reply with quote
Would it be worth putting a bit of loctite stud lock on it too?
Ian
PostPosted: Wed Apr 10, 2019 9:07 pm    Post subject: Reply with quote
I would.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Thu Apr 11, 2019 12:22 pm    Post subject: Reply with quote
Yeah you don't want it popping out again next time you do coffin arms.
MisterCorn
PostPosted: Thu Apr 11, 2019 12:36 pm    Post subject: Reply with quote
I have some loctite 290 which I can put on it. That should help.
IanG1
PostPosted: Fri Apr 12, 2019 3:22 pm    Post subject: Reply with quote
Big thanks to Martin MC. Looks like pressing out of the insert is a little more involved with a bit of work needed on my scrap hub to get to the top of it. Donation made to demorts daughters trip funding page as requested by MC to my offer of payment.
Thanks to all. who chipped in on my recent posts
Ian
PostPosted: Fri Apr 12, 2019 8:33 pm    Post subject: Reply with quote
ian and MC .. thank you very much but i think MC is probably the star here .. i just say what i can in an attempt to help out .. he has done the job Thumb
IanG1
PostPosted: Wed Apr 17, 2019 3:45 pm    Post subject: Reply with quote
All finished today, MC got the insert out of my scrap hub. Bit of grinding needed to get top side for the press to be able to get on it but it worked. Left in the freezer over night and popped in this morning. Used a nut and bolt to pull in the final few mm then toe arm ball joint in and tighten everything up. New disks pads and handbrake shoes,. Handbrake cable tube and jobs a good un.
Just my other coffin arm to do as I bought a pair and sort my Geo again.
