997 : 2004- 76
996 : 1997-2005 35
Boxster : 1997- 22
Cayman : 2005- 15
Cayenne : 2003- 3
Steve Gom
PostPosted: Wed Apr 10, 2019 2:57 pm    Post subject: Suspension Refresh with MO30 kit Reply with quote
Following feedback from my Indy after my recent service on the 996 I've decided to refresh the suspension with an MO30 kit and a visit to Center Gravity for a Geo. Car's mileage is now 102,500.
I don't believe I'll use the car on the track much but do like to enjoy the car to it's full potential on the quieter Northumberland roads, where I can and have been fairly impressed with the stock equipment's performance up to this point. The MO30 kit will give a slight ride height drop, but 10mm isn't going to make too much difference to the current stance but it should be a bit firmer with a bit more control from the beefier ARBs, without being too harsh on our poorer roads.
Having already replaced all 4 coffin arms and the front top mounts I've come to the conclusion the MO30 kit at £1,000 from my local OPC is pretty good value when you consider the costs of other springs and shocks alone. Yes, an Ohlins set up would be lovely (best upgrade I've ever done on my VFR800) but I think I'll achieve more for my budget with the MO30 kit in association with new rear upper control arms X4, front and rear track rod end outers X4 and ARB drop links X4. The latter parts came from CarParts4 less and FrazerPart for £320.
I've been perusing the excellent Q&A section of the forum and am weighing whether to take a couple of days off work to do the job myself versus giving my local garage £250 (as quoted, as long as nothing untoward crops up) which was half the cost of the labour required by my Indy. It’s just a suspension component swap, so not sure if a Porsche Specialist is really necessary, especially as the car will be going to CG for set up.
The Geo visit at CG is not until mid June so I wasn't planning to get things underway until the start of June, but either way this is going be close to a £2,000 job, so I’m hoping it’ll be worth it???
Very Happy Very Happy Very Happy
Steve
Slow in fast out...
1997 996 C2 manual
1998 RS 50th Anniversary VFR 800FiW
Paz
1998 Porsche 996 Carrera 2
PostPosted: Wed Apr 10, 2019 4:19 pm    Post subject: Reply with quote
Most definitely worth fitting the full M030 kit as supplied by OPC's.
Alas I never get my hands dirty so I usually get CG to replace everything, at least I know it'll be prepared and installed correctly.
Paynewright
PostPosted: Wed Apr 10, 2019 4:32 pm    Post subject: Reply with quote
Might be worth changing a few other bits whilst you are in there - my fromt bumpnstops were shot (only get new rears in the kit) and front top mounts (sachs from Autodoc in Germany - OEM part with number ground off but 1/4 price)
The bearings (according to CG) usually just need a clean and regrease which I did. I had to change 1 collar on the front which goes between the bearing and rubber spring seat - it was rusty and swelling.
The suspension has a few odd metric nuts and bolts not in your usuall range of spanners/sockets. Cannot remember which exactly but be prepared for a dash to halfords.
IanG1
PostPosted: Wed Apr 10, 2019 4:34 pm    Post subject: Reply with quote
16 and 18mm sockets and spanners will be what you need and not normally in usual sets as mentioned above.
1998 996.1 C2 manual/LSD with aero and a big smile
911munKy
PostPosted: Wed Apr 10, 2019 5:02 pm    Post subject: Reply with quote
I fitted M030 to mine, it’s not a hard job but be prepared for some seized components. I ended up removing my front struts and taking them to a local garage to remove/drill out various bolts (upper drop links) and cracked ABS sensors. If you are prepared to do that you will save on labour costs but it may take more than a couple of days overall. Top mounts for a C2 are cheap but most can be cleaned and regreased if there is no wear, rear top mounts should be fine. The M030 kit doesn’t come with rear bump stops (IIRC) so you will need to purchase them.
My M030 kit only lowered my car by a couple of mm as the original springs must have sagged, a couple of years later I replaced them with -30mm springs. My car handled much nicer with M030 fitted than with the original suspension.
2000 C2 996
Steve Gom
PostPosted: Wed Apr 10, 2019 8:56 pm    Post subject: Reply with quote
Cheers for the input folks.
The DIY route is looking less favourable as I keep hearing more "it was fine apart from the problem I had with this" and "eventually, after 2 days I had to cut that off"
I'm being told to factor in 2 full days' labour for all the work by my local garage, but 8 hours as the best case scenario, which is approx £250. They ve just done this exact same job on a 2005 80k mile 997 for the owner of the garage and got it done in a day, but you just don't know what's in store when you start stripping bits off.
I do like working on the car but I'd be miffed if I got stuck part way through the job due to an issue I couldn't overcome with the car on stands and half the running gear replaced and the rest refusing to surrender!!
Steve
Slow in fast out...
1997 996 C2 manual
Eldavo
PostPosted: Fri Apr 12, 2019 11:33 pm    Post subject: Reply with quote
Hi Steve,
We use the same Indy and my 996.2 had the M030 kit fitted from Porsche Teesside 500 miles before I got the car. If you want to see what it’s like then give me a shout as I’m NE3, just off the A1.
944 Turbo S - definitely not standard (his)
987 Boxster 2.7 - standard for now (hers)
996 3.6 Coupe - tastefully tweaked
toobusy
PostPosted: Sat Apr 13, 2019 9:20 am    Post subject: Reply with quote
My 996 has MO30 from new now has 109k miles and I had the full alignment at CG a couple of months ago. Set up is, of course, great and the MO30 was judged as fine and no leaks etc. They did ask whether I thought it too firm (nope - just right) so recommended I replace it with the same when the time comes, good value. Rural Lincolnshire has similar roads to Northumberland.
So, I bought a kit "for stock".. Having looked at it I'll be paying my local Indie to fit it and then CG for alignment when the time comes. It is very much "in bits" and I don't have the spring compressors etc. Having said that, it is just a box of components!
2003 Carrera 4, KTM, Jota
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Sat Apr 13, 2019 12:23 pm    Post subject: Reply with quote
@toobusy- interesting- did CG test the shock absorbers on their rig? Internet wisdom would have us believe shocks are dead by 100k miles...
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sat Apr 13, 2019 12:38 pm    Post subject: Reply with quote
CG checked mine at around 100k miles and they were still fine, I eventually changed them for new around 110k but they didn't really need to be.
toobusy
PostPosted: Sat Apr 13, 2019 6:00 pm    Post subject: Reply with quote
Hi Chris!
RobertB - Yes they did. I had the full Porsche clinic check in January and they said that apart from some sag in the springs they were ok. They did recommend some other replacements such as a top mount and coffin arms (which I had done locally) but that was all.
I usually plan for one "upgrade" each year and so M030 will probably be fitted next year. Deep sump this year....
Stotty
PostPosted: Sun Apr 14, 2019 10:40 am    Post subject: Reply with quote
Mine was still on original shocks at 170k miles. It still drive ok.
2000 996, C2, manual, arctic/metropole, Koni shocks, H&R -30 springs, H&R ARB's, Rennline SS engine mounts, cup wheel, 170k miles. 2018 Touareg RLine Plus
Steve Gom
PostPosted: Sun Apr 14, 2019 9:00 pm    Post subject: Reply with quote
Cheers Eldavo I did test drive an early 996 with MO30 suspension and wouldn't say it was much different to mine. Unfortunately I didn't get to test drive that car the way I've learned how to drive mine, so hard to make a proper comparison.
The ride in my car is pretty good but I'm just trying to update/refresh things to continually improve the driving experience.
Too busy - love the roads around NE Lincs, I used to live in Cleethorpes!
Chris from CG has been really helpful so far and I'm hoping once the new suspension components have been fitted I'll be able get the car dialled into how I like things but I'm going to try some trips over roads I'm familiar with to get a feel for the 'new and better' suspension before I get to CG for some fine tuning and improved set up.
Steve
Slow in fast out...
1997 996 C2 manual
Steve Gom
PostPosted: Fri Jun 07, 2019 3:18 pm    Post subject: Reply with quote
Collecting car tonight Smile Smile Smile
Steve
Slow in fast out...
1997 996 C2 manual
 Filesize:  915.23 KB
 Viewed:  289 Time(s)
 Filesize:  998.52 KB
 Viewed:  289 Time(s)
 Filesize:  867.6 KB
 Viewed:  289 Time(s)
