997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 17
easternjets
PostPosted: Tue Apr 09, 2019 6:12 pm    Post subject: Sharkwerks silencer delete for 997 gen 2 Turbo Reply with quote
I will shortly have a Sharkwerks pipe available for a 997 Gen 2 Turbo.
I have attached a picture to show it in place.
Made from T304 Stainless Steel and weighing 8 lb's less than a std exhaust.
This really makes a massive difference to a gen 2 turbo, put it in Sport mode and you get an amazing sound from the car when you press on!
I believe these are around £1370 from the U.S. Current price is $1595 plus carriage to the U.K.
I want £775.00 delivered to your U.K. address by courier.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
 Filesize:  838.28 KB
 Viewed:  1141 Time(s)
DJP997
PostPosted: Sat Apr 20, 2019 7:28 pm    Post subject: Reply with quote
Hi, couple of questions -
Is this also known as 'X pipe' ?
Where is this item coming from ?
Cheers,
Darren
997 GenII Turbo
TwinBoost
PostPosted: Sun Apr 21, 2019 5:43 am    Post subject: Reply with quote
PM Sent
997 Turbo S
Sold:
996 Turbo - Speedtech X-Pipe
easternjets
PostPosted: Sun Apr 21, 2019 8:31 am    Post subject: Reply with quote
Yes as you can tell from the picture they are called an 'X' pipe, the std silencer is open so the two pipes meet in the box with this set up the two exhausts are kept entirely separate.
They are made in U.S. by Sharkwerks so if you order one through their site it will be airfreighted over with all the additional charges. I'm not a 100% sure if there is anybody in this country importing them but I doubt there would be a huge demand to make it worth their while.
For now I'm keeping my car so my item is no longer available. Just can't part with my car!
997 Turbo Gen 2
Porsche 928 S4
AdeD
2010 Porsche 997 Turbo
PostPosted: Sun Apr 21, 2019 9:18 am    Post subject: Reply with quote
I was tempted with this but i'm more pleased you're keeping the car Thumb
997.2 Turbo | 19" HRE's | BBI Cage | Ohlins | H&R Front & Rear ARB's | GT2RS Carbon Seats | DesignLS Custom Retrim | DO88 Intercoolers, Y-Pipe & Inlet Hoses | IPD Plenum | WaterMeth Injection | Equal Length Headers & 3" DeCat Exhaust
easternjets
PostPosted: Sun Apr 21, 2019 12:05 pm    Post subject: Reply with quote
By the way if anyone's wondering, they do not set off any warning lights on your dash or need a remap. They are fairly straight forward to fit as long as your CAT nuts are in good shape. You do need to slacken off the D/S CAT to fit the pipe in as it is a one piece unit.
You don't get a 'drone' from them but you do get a bit of a rumble when you accelerate in a higher gear, they do change the whole sound effect of a Turbo and are about a quarter of the price of a Kline, not knocking the Kline but they are an expensive unit for more or less the same effect.
Personally the two easiest and most effective upgrades on a Turbo are this and a DSC module and if you buy them S/H also the cheapest!
997 Turbo Gen 2
Porsche 928 S4
kingroon
PostPosted: Thu May 16, 2019 2:25 pm    Post subject: Reply with quote
I had one of these on my 997.2 Turbo S, and all I can say is that it literally transforms the car for very little money.. It sounds sooooo much better, it should be done on all 997 Turbos..!
To confirm, no Dash Lights, or Warnings are set off, and a remap is definitely not required.. It simply allows the Exhaust to get out of the Engine quicker [which is what all Engines want] and does it with a beautiful Growl and Burble..
Hasta Luego..
KingRoon
1994 993 Carrera Coupe
 Filesize:  156.19 KB
 Viewed:  438 Time(s)
 Filesize:  241.75 KB
 Viewed:  438 Time(s)
