997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 15
DucatiRob
PostPosted: Mon Apr 08, 2019 9:15 am    Post subject: Water Pump Replacement - how much coolant Reply with quote
Planning to replace my water pump at the weekend, I know there is something like 8 gallons of coolant in the whole system but have read that you only lose around 2 gallons when changing the pump. Anyone done this job, any tips? Will need a bigger bucket if I need to drain 8 gallons Surprised
Mercedes CLK DD
Ducati 996
PostPosted: Mon Apr 08, 2019 4:18 pm    Post subject: Reply with quote
I've never actually measured it but i expect about 7-8 ltrs at most for just the water pump .
timbo1811
PostPosted: Mon Apr 08, 2019 5:24 pm    Post subject: Re: Water Pump Replacement - how much coolant Reply with quote
there are some good tutorials about, from memory, I removed engine mounts, there are a couple of difficult bolts to get at on the pump, you almost need a flexi drive. Its possible to snag the gasket while putting the pump back so need to be extra careful. The gasket doesn't look like a gasket, its metal, but it works. Got my pump from Autodoc, excellent price and OEM.
Lotus Elan, Lotus Elan +2, MGA Mk11, TR4, 230 Compressor, 320 coupe, 944, Boxster 2.7, 997.1(current), VFR 1200, CBR 1100 Blackbird
DucatiRob
PostPosted: Mon Apr 08, 2019 8:12 pm    Post subject: Reply with quote
Thanks deMort Thumb sounds about right then!
Mercedes CLK DD
Ducati 996
DucatiRob
PostPosted: Mon Apr 08, 2019 8:20 pm    Post subject: Re: Water Pump Replacement - how much coolant Reply with quote
Cheers timbo, have read a few of the tutorials and there is a good video on Youtube but they never cover everything! Looks a pretty easy job though! Ordered my pump and alternator from Autodoc, good prices. I ordered the Pierburg pump, think they are the OEM manufacturer, and it comes with a new gasket Thumb
Mercedes CLK DD
Ducati 996
bobi61
PostPosted: Mon May 06, 2019 6:38 pm    Post subject: Reply with quote
did you change the water pump ??
DucatiRob
PostPosted: Mon May 06, 2019 10:06 pm    Post subject: Reply with quote
Yes I sis a couple of weeks ago, pita of a job but not difficult! Needed about 6 /7 litres of coolant to top up after Thumb
Mercedes CLK DD
Ducati 996
PostPosted: Tue May 07, 2019 7:25 pm    Post subject: Reply with quote
i was a litre out on my guess !
btw .. June 29 .. meets section .. come say hello Very Happy
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Tue May 07, 2019 9:54 pm    Post subject: Reply with quote
I'm currently swapping my 996 pump and always find that a 10L bucket is perfect for draining the coolant to do any jobs on the coolant system front or rear. I always re-use the same coolant I removed as its perfectly clean still but I will filter it before putting it back in.
THE difficult bolt to get out was tricky but I managed it using a short 10mm socket plus 3/8 wobble bar with an extension on it as I couldn't get any kind of ratchet in there and a spanner didn't have any movement.
DucatiRob
PostPosted: Tue May 07, 2019 10:16 pm    Post subject: Reply with quote
In my diary deMort Thumb
Mercedes CLK DD
Ducati 996
DucatiRob
PostPosted: Tue May 07, 2019 10:19 pm    Post subject: Reply with quote
Took me at least half an hour to undo THAT bolt Mad undoing it with a small ratchet was no problem, actually removing it millimetre by millimetre nearly broke me frustrated
Mercedes CLK DD
Ducati 996
timbo1811
PostPosted: Wed May 08, 2019 10:12 am    Post subject: Reply with quote
ahhhh, that bolt!! Mad
easternjets
PostPosted: Wed May 08, 2019 10:29 am    Post subject: Reply with quote
You want to do the one on a 997.1 Turbo, you can see it but to get at it I had to pull the engine mount plate out of the way.
Couldn't believe the difference in price between OPC and Autodoc, think I saved best part of £300 buying Autodoc's Pierburg pump which is what Porsche fit as std.
It's also a good shout if your buying a 997 to check for weeps around the pump/pipe as there was when I bought my 1st car. Dealer told me it was a weeping pipe which needed refitting and tightening, it wasn't it was the pump which I believe is a £1000 bill from an OPC, for a Turbo as the whole exhaust has to come off.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
PostPosted: Wed May 08, 2019 7:24 pm    Post subject: Reply with quote
If it helps then i don't have any easy answer for That Bolt !
YUP ..we all know what we are talking about when it comes to the bolt lol
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Wed May 08, 2019 8:25 pm    Post subject: Reply with quote
I refitted my water pump today and after trying every socket and extension combination I could, this was the easiest set up by far and only took me a minute to tighten it back up.
A short 10mm socket 1/2" drive, a T bar with 1/4" drive and a converter from 1/4" to 1/2" inbetween them.
My deep extensions are too long to get in and my normal sockets are too small and the ratchets heads are all too large to be able to spin, even my 1/4" ones, the above was perfect. I extended the T bar a little to actually nip the bolt up at the end.
