997 : 2004- 72
996 : 1997-2005 29
Boxster : 1997- 18
Cayman : 2005- 20
Jneil964
PostPosted: Sun Apr 07, 2019 7:37 pm    Post subject: 997 gear linkage on 996 Reply with quote
Hi all, I have been researching short shift kits and alternatives for my 996 C4S and finally decided on replacing the gear linkage with the 997 part. The reason for changing the unit is that 2nd to 3rd was always notchy and the same from say 5th to 3th.
I replaced the unit today and thought I would give you guys an update. The gear shift is certainly better from 2nd to 3rd - much smoother but the issue with 5th to 3rd is the same and a double de clutch is best here. Although the 997 unit is probably more robust as there is a steel plate reinforcing the plastic parts I am not sure it’s such a difference to warrant the expense . I only did 15 miles so maybe I will think differently on a longer run!! Surprised
PostPosted: Sun Apr 07, 2019 7:57 pm    Post subject: Reply with quote
First off .. i'm unsure of what items you have changed ... any part numbers or pictures ?
Gear selection problems .. they are normally caused by the synchro on each gear ..
Its a brass cone ring with a steel internal ring .. as one engages the other it slows the 2 gears to a similar speed .. the syncro gear can then slide over the 2 .. if they are not the same speed then you will get crunching of the gear change ... or Bulking.
When they wear it won't slow the 2 rings fast enough and you will get crunching .. it helps if you double the clutch or slow change the gear change .
video here helps explain it ..
https://www.youtube.com/watch?v=MXsRfbOiBhE
more info please Smile
skinny_monkey
PostPosted: Mon Apr 08, 2019 11:08 am    Post subject: Reply with quote
Are the cables properly adjusted?
