997 : 2004- 73
996 : 1997-2005 29
Boxster : 1997- 18
Cayman : 2005- 20
Stewtomcat
PostPosted: Mon Apr 01, 2019 4:43 pm    Post subject: IMS Reply with quote
Hi all how much a risk is there in buying a 2005 Carrera S tiptronic with 80k on the clock having IMS failure ?
Regards Stewart
PostPosted: Mon Apr 01, 2019 5:28 pm    Post subject: Reply with quote
Very very low, ie. Less than 1%
PostPosted: Mon Apr 01, 2019 5:29 pm    Post subject: Reply with quote
You should be more concerned about bore-score, especially on a tiptronic Carrera S.
PostPosted: Mon Apr 01, 2019 6:14 pm    Post subject: Reply with quote
A late 2005 car would be less of a risk as it would have had the latest IMS bearing.
If it's an engine number after M97/01685 09790 you should be ok.
Sadly, whilst the % risk is small it's a lottery as to which cars will be in that small %.
At 80k miles on a Tip 'S' I'd be more concerned about the level of bore-scoring.
PostPosted: Mon Apr 01, 2019 6:44 pm    Post subject: Reply with quote
Get a ppi inspection and a bore scope check done on any vehicle you are serious about .. you can always post the bore score pictures here if needed .
As per T8 comment .. 2006 is better ... look at the chassis number .. you want 6 .
 Filesize:  18.05 KB
 Viewed:  423 Time(s)
Kettmark
PostPosted: Mon Apr 01, 2019 6:46 pm    Post subject: Reply with quote
Get a borescope test at a good indi or a warranty. Failing that buy one that's had a rebuild engine from a reputable source with receipts. Plenty to choose from so be picky.
PostPosted: Mon Apr 01, 2019 7:36 pm    Post subject: Reply with quote
Deffo plenty of rebuilt tiptronic Carrera S' to choose from Grin
