997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 17
nickjonesn4
PostPosted: Mon Apr 01, 2019 12:44 pm    Post subject: Brakes - to upgrade or not Reply with quote
Hello All,
Just about to book my car into SPAutobahn for post-winter jobs. Chief amongst these is the discs and pads need changing and my mind has wandered to the pros and cons of upgrading the brakes to the package on the Carnewal website
http://www.carnewal.com/products/993/p93133/Big-Red-Brake-Package
Am still planning engine upgrade work this year now my wallet has recovered from last year's extravaganza and also booked in for several track days so inching towards going for it. Any thoughts from those who have made the change ??
1996 Carrera 2S Vesuvius Metallic
2016 Golf R
2005 E55K Wagon
Sutton
PostPosted: Mon Apr 01, 2019 3:06 pm    Post subject: Reply with quote
I never felt I needed bigger brakes, even on track. I tend to use engine braking together with the brakes, even on the road.
The bigger brakes increase unsprung weight too so I was looking at two piece front brakes from Racing Brake.
https://www.racingbrake.com/RB-Two-piece-Rotor-for-Porsche-993-non-Turbo-Fro-p/2519.htm
They are the same size as standard brakes but have an aluminium hat. The other option to have a look at, is better cooling for the front discs from Gert.
http://www.carnewal.com/products/993/p93061/Brake-Ducts-with-Fog-lights
1994 993 C4
cableguy
PostPosted: Mon Apr 01, 2019 4:00 pm    Post subject: Reply with quote
Standard brakes in well serviced and good order should be all the brake you'll ever need on UK roads IMO.
I actually prefer the look of the understated standard Black Caliper, Red has always been a little "shouty" for my liking! Grin
C.
Pork!
tyinsky
1997 Porsche 993 Carrera 2S
PostPosted: Mon Apr 01, 2019 5:21 pm    Post subject: Reply with quote
Got these on my car. No idea if they make much difference but they look nice Grin
nickjonesn4
PostPosted: Mon Apr 01, 2019 6:40 pm    Post subject: Reply with quote
Cheers. I had the same thought on unsprung weight, interesting option in upgrading the discs. Presumably the pads can be upgraded also.
Will take a look at the cooling option also Thumb
2016 Golf R
2005 E55K Wagon
nickjonesn4
PostPosted: Mon Apr 01, 2019 6:43 pm    Post subject: Reply with quote
C.
Hey Carl. Yes I agree on the road use more from experience cooking brakes on track in other cars.
100% on the black calipers. Red would look hideous with the colour of my car so would have to tricolour anyway. Did 928s not have "big blacks"?
2016 Golf R
2005 E55K Wagon
nickjonesn4
PostPosted: Mon Apr 01, 2019 6:46 pm    Post subject: Reply with quote
Floor Floor modding for moddings sake
2016 Golf R
2005 E55K Wagon
cableguy
PostPosted: Mon Apr 01, 2019 7:28 pm    Post subject: Reply with quote
C.
The 928 manufactured in the same year was a good 200kgs+ heavier so it's possible the anchors were a little beefier, particularly with the V8 lump over the front axle. Wink
C.
Pork!
Endoman
PostPosted: Mon Apr 01, 2019 9:10 pm    Post subject: Reply with quote
Std 928 calipers and discs were same as 993 but mounted trailing and different disc offset
928 GTS "Big Blacks" were same size as 993RS and Turbo "Big Reds"
I have 993 std calipers on my 944 front same size as M030 with 928 discs but you have to flip the bleeder and cross pipe and you need an adapter to mount them radially. With normal Textar pads they work really well on track.
I agree that std discs and calipers on a 993 in good order are totally adequate even for trackday use.
 Filesize:  128.81 KB
 Viewed:  1294 Time(s)
stuttgartmetal
PostPosted: Mon Apr 01, 2019 9:31 pm    Post subject: Reply with quote
Plate lift no doubt
Get the calipers refurbed, and discs and pads from Eurocarparts
Your problems will all be behind you.
nickjonesn4
PostPosted: Mon Apr 01, 2019 9:59 pm    Post subject: Reply with quote
Cheers. I knew I had read that somewhere on the "big blacks", didn't know it was GTS only.
I will go ahead and get the discs and pads changed and then take it from there. Will get the calipers checked over and refurbed if necessary.
2016 Golf R
2005 E55K Wagon
stuttgartmetal
PostPosted: Mon Apr 01, 2019 10:01 pm    Post subject: Reply with quote
Plate lift no doubt
nickjonesn4
stuttgartmetal wrote:
Plate lift no doubt
Thanks. There is a massive sale at eurocarparts at the mo, just bought discs and pads for my AMG at 40% discount
2016 Golf R
2005 E55K Wagon
stuttgartmetal
PostPosted: Mon Apr 01, 2019 10:09 pm    Post subject: Reply with quote
Plate lift no doubt
nickjonesn4
PostPosted: Mon Apr 01, 2019 10:15 pm    Post subject: Reply with quote
Plate lift no doubt
Are the Sebro discs the OEM option?
2016 Golf R
2005 E55K Wagon
nickjonesn4
PostPosted: Mon Apr 01, 2019 10:23 pm    Post subject: Reply with quote
if anyone is after discs and pads there is 55% off on eurocarparts for the next 30 mins. Just about to pay £412 all in
2016 Golf R
2005 E55K Wagon
Dream911
PostPosted: Mon Apr 01, 2019 10:30 pm    Post subject: Reply with quote
Plate lift no doubt
Make sure you check around. Often they are the cheapest but the saving aren’t quite what they seem as they hike up the price prior to the “big sale”. Bought a new Bosch S5 battery from them in the weekend as I need it within the hour so clicked and collected for £98 using the 50% off code so down from £196 but it’s hardly 50% when the std price on their sister site carparts4less lists the same battery for £128 (and they always have £15 off) and I could have bought from a few other places at £100.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Apr 01, 2019 10:34 pm    Post subject: Reply with quote
Good for batteries if there is a branch near you when you need to swap under warranty.
nickjonesn4
PostPosted: Mon Apr 01, 2019 10:43 pm    Post subject: Reply with quote
Dream911 wrote:
Plate lift no doubt
Had a quick check and the brake parts are a brilliant deal. Just deleted the battery from the basket however!!
2016 Golf R
2005 E55K Wagon
nickjonesn4
PostPosted: Mon Apr 01, 2019 10:54 pm    Post subject: Reply with quote
Whats the view on braided hoses with SS connectors, goodridge or similar as an upgrade whilst the brakes are being done?
2016 Golf R
2005 E55K Wagon
