997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
jcharalambides
PostPosted: Mon Apr 01, 2019 11:38 am    Post subject: KW V3 vs KW Clubsport - Track and road use Reply with quote
Hi all,
Looking at doing a full suspension refresh on a 996.2 C2 manual.
Usage will be 50% track days/ 50% weekend fun.
Does anyone have experience of the KW V3 and Clubsport kits?
I'm wondering if:
- the V3 might feel to soft for the track if i progress well?
- the Clubsport will be unbearable on the road even playing with the rebound and compression settings?
Any views based on experience would be great.
thanks
james
Paz
1998 Porsche 996 Carrera 2
PostPosted: Tue Apr 02, 2019 9:26 pm    Post subject: Reply with quote
Admittedly not a 996 but years ago I had a daily 968 Sport in which I did fourteen UK trackdays in two years, I had Center Gravity install/setup the KW v3 kit.
For coilovers they're supremely comfortable on the road.
They were progressively tweaked as I gained more experience on track and the kit proved to be excellent on track and not unduly harsh on the road (for a coilover kit).
I gather the Clubsport kit is sold without a warranty.
For the very slight increase in price I would probably go for an equivalent Bilstein kit, purely because I find the build quality to be better imho.
Good luck and enjoy.
jcharalambides
PostPosted: Wed Apr 03, 2019 12:44 pm    Post subject: Reply with quote
Thanks for sharing the experience Paz. Very helpful.
I spoke with the guys who look after my car - they use KW and know how to set these up with the rest of the suspension, hence i am not looking at other brands. Their view was that:
1. the Clubsport being motorsport equipment needs a lot more regular maintenance. They mentioned the CS has a bigger strut with less lateral movement and as a result the seals are more likely to leak
2. the V3 will be great on the road and very capable on track. This is consistent with what you say
3. on build quality they rate KW highly and as my car sleeps outside they commented that they were less likely to rust than other brands
I'll likely be going with the V3 with ARBs, etc to match.
Will report with impressions when i get it all done, but hopefully the above is helpful to whoever has the same question in the future!
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Wed Apr 03, 2019 12:45 pm    Post subject: Reply with quote
Stick to the KW v3 not the Clubsport models
This is from experience from a 996
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON TWITTER
jcharalambides
PostPosted: Wed Apr 03, 2019 12:53 pm    Post subject: Reply with quote
Thanks for the advice!
Are you able to elaborate on the performance of either for track and road use respectively?
snb993
PostPosted: Wed Apr 03, 2019 3:49 pm    Post subject: Reply with quote
Hi
I had mine changed to KWv3 within the first year of buying my 996T. that was 12 years ago now and I still think that it's brilliant.
Mine are set for bump and rebound at just over half (from memory as the details are at home) and heightwise at approx. 3RS
Mine gets used for about 4,000 miles a year - 2 or 3 track days and the rest on our EU drives
I would say that the ride comfort/quality feels spot on - not harsh at all . plenty of feel. Could easily be OEM
Geo wise it was reset by CG last year having had new coffin arms. They commented that the springs had dropped a bit (normal apparently) but otherwise it is still in great condition. Also gave me a chance to try H&R ARB's
Very Happy
Recommended IMHO
thumbsup
996T - Cobalt blue, K24's, GT2 I/C's, Techart SSK, Manthey KWv3, H&R ARB's, RS engine mounts, Europipe, GT3RS 6 pots, 997T discs/RS29's all round etc
964 C4 - GP white, 993 C4 gearbox/front diff, Wayne remap, Bilstein B6's / H&R springs, polybushed, Cup 1's, RS SSK, gutted cat etc
993C4 - sold
928S4 - sold
Paz
PostPosted: Wed Apr 03, 2019 9:38 pm    Post subject: Reply with quote
Just my humble opinion but I'd be inclined to recommend Eibach anti-roll bars purely for the fact that they are tubular and thus give a progressive rate of stiffness in use, they're also extremely light.
The H&R anti-roll bars tend to be solid metal and ridiculously heavy in comparison, one has to wonder, are they actually flexing enough to give you the adjustability in your road and track driving?
Martin996RSR
PostPosted: Thu Apr 04, 2019 8:37 am    Post subject: Reply with quote
Anti-roll bars are just torsion springs, with no real difference in terms of complexity from a coil spring. The problem with them comes from the manufacturers rarely publishing figures for their stiffness/rate. They are normally just published as having a certain diameter. Solid bars are a lot heavier and for that reason alone should be avoided, as there are plenty of hollow bars to choose from. Don't get hung up on brands, just buy a second hand OE hollow bar that's thicker than what you already have for £20 from ebay and get it powder coated for £40 and hey presto you'll have something for a fraction of the price of a Whiteline/Eibach/H&R bar.
It's also very easy to modify a hollow rear bar to make it adjustable. I had mine done for £10 at a local engineering place.
jcharalambides
PostPosted: Thu Apr 04, 2019 9:15 am    Post subject: Reply with quote
@snb993 - just what i wanted to hear, thanks!
@Paz - the plan right now is to go with Eibach hollow ARB and lower arms, new top mounts and RSS engine mounts. Need to figure out how bad the engine rebuild bill we be before pulling the trigger on this though ... Sad
@Martin996RSR those are some interesting insights. Since I know nothing about suspension I am going with the recipe that my independent uses, having tried and tested combinations over time
