997 : 2004- 70
Boxster : 1997- 13
Rob325114
PostPosted: Tue Mar 26, 2019 10:13 pm    Post subject: Slight clunking noise on take off, then loud drone Reply with quote
Hi all,
On the way home from work this evening I noticed a slight clunk from the rear when taking off from a standstill. It's really slight, but seems to be just as the transmission engages to move the car forward.
Then, more worryingly I noticed a loud droning noise when accelerating on the motorway. Its only once you're getting around the 4/5kprm Mark. Almost like the exhaust is blowing.
The car is under OPC, but they can't get it in until next week, and it's my daily. Any ideas? Would you continue to drive?
Current: Agate Grey 991.1 C2S Coupe, PDK
Ex: Black 997.1 Hartech'd C2S Cab, manual
Ex: Silver Citroen C2 GT, manual
Ex: Blue Ford Fiesta Zetec S 1.6, manual
Luddite
PostPosted: Wed Mar 27, 2019 8:25 am    Post subject: Reply with quote
Might be worth enquiring if any local garage/exhaust centre might put it on their ramp for no more than a few minutes to have a quick look for anything obvious..? A reasonable donation to the tea and buns kitty might be all that is required.. Question
if that is not possible have someone rev it to 4-5k and roll around on the ground to feel, see, smell if exhaust it exiting from other than the tail pipes.. or very temporarily hold something in front of one of the tailpipes to block it off and listen for exhaust exiting from elsewhere, repeat the process with the other and compare ...
Hope it turns out to be no real problem.
Rob325114
PostPosted: Wed Mar 27, 2019 11:41 am    Post subject: Reply with quote
Thanks Luddite. The car really decided to prevent me driving today with a flat tyre. So my OPC have agreed to slot me in this week to sort everything out.
I'll let you know what it turns out to be. My hunch is that is related to a mounting of some kind - exhaust, engine, etc. I don't feel like it's structural to the suspension, etc, as it only when the transmission engages, rather than steering etc.
