Bleeding power brakes
stuttgartmetal
23 Feb 2009
2,519
Any good tips or a follow step guide
1996 C4S with ABD ABS Power Brakes
How's it done.
I have that globe up by the fuel tank.
Look at the fluid coming out of it. :grin:
Not so long ago, I'd have had an answer.
How do you bleed power brakes from dry ?
I have an intermittent ABS and ABD warning light showing.
I can flip the ignition off/on and it goes out for a short while.
I recently had the four calipers refurbished, and changed brake fluid at the bleed nipples on each separate one, starting at rear right.
I never knew about the globe.
I'm guessing I must have to change the fluid again, starting at the globe.
Any advice ?
I think a test of the ABS system is in order on the first damp/wet drive. The internals of the pump seize if not exercised.
124,604
1,442,010
49,036
barrywhite
