997 : 2004- 67
996 : 1997-2005 34
Boxster : 1997- 21
Cayenne : 2003- 3
Marc D
PostPosted: Sun Mar 24, 2019 4:28 pm    Post subject: Cold gear change issues Reply with quote
Hi, got a 996.1 3.4 and when it’s cold I have difficulty selecting 1st and 2nd. It’s ok if the clutch has been in for a few seconds. When the car has warmed up after driving for about 5 minutes it’s fine going into 1st but 2nd is still a little stiff to go in although once it’s fully arm 2nd is fine. I’ve tried changing the gearbox oil to redline 75/90ns which helped a tiny bit and also new semi solid engine mounts and powerflex gearbox insert which made the shifting smoother when the car is fully warmed up through all the gears but still very stiff when cold. Anyone had similar issues and know how to improve or sort it out?
Thanks Marc
PostPosted: Sun Mar 24, 2019 4:33 pm    Post subject: Reply with quote
Drop 10% of the oil out. thumbsup
PostPosted: Sun Mar 24, 2019 5:31 pm    Post subject: Reply with quote
Marc, Alex's answer is not a joke , its a known fix for your issue Thumb Thumb
Marc D
PostPosted: Sun Mar 24, 2019 5:40 pm    Post subject: Reply with quote
Oh right ok cheers guys will drain a couple of hundred ml out tomorrow. When I filled it up I did try and get as much as I could in, clearly the wrong way to do it with these cars lol
Ghianightmare
PostPosted: Sun Mar 24, 2019 11:25 pm    Post subject: Reply with quote
Does this apply to the 996.2?
2002 Seal Grey C4S
PostPosted: Mon Mar 25, 2019 7:32 am    Post subject: Reply with quote
Mercedes did a recall on their manual boxes around the same era for the same problem.
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Wed Mar 27, 2019 5:09 pm    Post subject: Reply with quote
Haven’t heard of this one. Any idea if it also applies to the ‘96 993 boxes?
Ex. '99 996 C2 manual coupe.
PostPosted: Wed Mar 27, 2019 6:07 pm    Post subject: Reply with quote
Applies to any boxes. When the oil is cold it's too thick and creates problems. Less of it helps.
ballcock
PostPosted: Thu Mar 28, 2019 10:33 am    Post subject: Reply with quote
Cheers.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Thu Mar 28, 2019 1:28 pm    Post subject: Reply with quote
But don't they suggest that amount of oil for a reason... might running less cause additional wear?
wasz
1999 Porsche 996 Carrera 2
PostPosted: Thu Mar 28, 2019 3:48 pm    Post subject: Reply with quote
Could be the oil?
I filled mine with triple qx oil and it was awful, worse.
Refilled with Motul and its been much much better ever since (not perfect, they are all a little difficult when cold with a few miles on them). Same spec oil.
OE Porsche oil is a fairly difficult to find mobil oil I heard, but can be bought in europe for cheaper than the OPC.
maldren
PostPosted: Thu Mar 28, 2019 4:40 pm    Post subject: Reply with quote
wasz wrote:
Could be the oil?
I found the same, Motul, filled to the line and it baulks a bit when cold but fine once warmed up.
I may try taking a bit of oil out as per Alex's tip, any ideas how much?
Mike
