Boxster : 1997- 18
Cayman : 2005- 20
Exelzion
PostPosted: Sun Mar 24, 2019 9:16 am    Post subject: after a 997 Reply with quote
Hi, im looking for a good, solid 997.1 4S with the IMS done.
Or
a 997.2 4S
I'm not bothered about the color, just aslong the interior is black.
Im not looking to pay anything over priced as i don't plan to keep it for too long as i plan to move to North Carolina in the next few years.
If anyone has one for sale, let me know here please. i want to say away from ebay ect, id rather get a car from an enthusiast.
Also if you know anyone who wants a cheap 996.2 let me know as i want to sell this one i have, cheers guys
Porsche - There is no substitute!
----- Porsche 994
1998 Porsche 2.5 Boxster
1998 Porsche 3.4 Carrera 2
2005 Porsche 3.8 Carrers 2S
2002 Porsche 3.6 Carrera 4
PostPosted: Sun Mar 24, 2019 9:21 am    Post subject: Reply with quote
Do some homework on the 3.8 gen 1. The issue is bore scoring not ims.
Exelzion
PostPosted: Sun Mar 24, 2019 9:43 am    Post subject: Reply with quote
Ive done my homework, my previous 997.1 had an IMS fault and i had to sell it for 13k, so making sure it gets done in my new purchase.It also had bore scoring too ( or atleast so he said when he put the camera in ).
Ideally, i would prefer both done.
Im not one for going crazy over IMS, my 2002 996.2 hasn't had the IMS done and its perfectly fine, but paying around 20k+ i really do want it done after my previous experience of these cars.
----- Porsche 994
Drybeer
PostPosted: Sun Mar 24, 2019 9:56 am    Post subject: Reply with quote
What's the going rate for a preventative measures IMS upgrade these days?
At somewhere like Autofarm or Hartech?
PostPosted: Sun Mar 24, 2019 10:00 am    Post subject: Reply with quote
About £4k as the only realistic preventative measure is an engine rebuild and bigger bearing fitted.
PostPosted: Sun Mar 24, 2019 1:59 pm    Post subject: Reply with quote
Get a car with the newer IMS bearing post march 2006 all were the newer better IMS but some 05 cars were done , heres the definitive engine numbers .
Last IMS revision before no IMS (Gen2 MA1 block):
997 Carrera 3.6 with engine numbers from M96/0569507475 are the new IMS design.
M96/05 = 997 3.6 Carrera NA
6 = 6 cylinders
9 = design revision
5 = year (2005)
07475 = cumulative production serial
This means some MY2005 benefit and all MY2006 onwards benefit.
997 Carrera S 3.8 with engine numbers from M97/0168509790 are the new IMS design.
M97/01 = 997 3.8 Carrera NA
6 = 6 cylinders
8 = design revision
5 = year (2005)
09790 = cumulative production serial
if you want the lowest risk of borescore and cant find a rebuild to buy then go for a 997.1 3.6 manual car . but get it scoped as part of your PPI
MattyR
PostPosted: Sun Mar 24, 2019 6:42 pm    Post subject: Re: after a 997 Reply with quote
Or
a 997.2 4S
I wouldn’t discount a 3.6ltr 997.2 either as these can be a bargain; especially when one considers the performance figures alongside a gen 1 S model.
Atlas Grau on Ocean Blue Gen 2 997 C2 Carrera
Sold: Aventura Grün 993 C2 Carrera
benbuhagiar
2008 Porsche 997 Carrera 2
PostPosted: Mon Mar 25, 2019 10:38 am    Post subject: Reply with quote
If you can afford a Gen 2, buy a Gen 2.
Agree with above comment, 3.6 gen 2 is a real "bargain". Although I am somewhat biased. Drive one and you won't be disappointed.
997.2 Carrera PDK
SausageCreature
PostPosted: Tue Mar 26, 2019 8:16 am    Post subject: Reply with quote
Could you explain a bit more for me please? Why would the engine need a rebuild when a new bearing is fitted? Or do you mean £4k is the cost of a rebuild and upgraded IMS on an engine that has already failed?
I thought that an upgraded IMS bearing could be fitted at the time when a clutch change is done. Surely this cannot be £4k?
An upgraded bearing is in the realms of £500 for parts (that is an expensive bearing).
M
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Tue Mar 26, 2019 6:12 pm    Post subject: Reply with quote
Alex can speak for himself of course, but I think he's referring to the machining needed to covert to the later, larger diameter bearing.
Hamster75
PostPosted: Wed Mar 27, 2019 9:12 pm    Post subject: Re: after a 997 Reply with quote
MattyR wrote:
Or
a 997.2 4S
I had a 3.6 gen 2 for 4 years ran like a sewing machine I did the standard services with opc main dealer & filters belts other than that I spent nothing on it had 45000 on it when I sold it, so based on my experience I would recommend the Gen 2 -main dealer was keen to buy back & based on that it tells a storey, if you can find one mid £30k`s I say its a good deal.
resigner
PostPosted: Wed Mar 27, 2019 10:02 pm    Post subject: Reply with quote
Convinced Alex is a Golf R owning Troll.........
Razz
Lambretta
PostPosted: Thu Mar 28, 2019 8:13 pm    Post subject: Reply with quote
Buy a 06> car dont worry about IMS
early 04 to 05 (approx) cars, the IMS can be replaced relitivly easy, with the clutch removed around £1-1500 the later cars late 05> (approx) if you want this upraded the IMS is within the engine case and would require the case spliting as mentioned above
997 Seal Grey Manual
1966 912 under resto
Iwantone
PostPosted: Fri Mar 29, 2019 12:46 pm    Post subject: Reply with quote
I have reluctantly put my 997.2 C4S up for sale. Feel free to ping me if you have any questions.
http://911uk.com/ads_item.php?id=8949&sid=f24e2f2acbbcc3303c73031d3fd4e9b8
Steve
Current: 2009 Gen II C4S
Previous: 1988 Carrera 3.2
and various non-Porsche in between
benbuhagiar
PostPosted: Fri Mar 29, 2019 1:52 pm    Post subject: Reply with quote
Steve
A very good price. Won't hang around long I bet.
997.2 Carrera PDK
Iwantone
PostPosted: Fri Mar 29, 2019 10:16 pm    Post subject: Reply with quote
Steve
I think so...it’ll be sad to see her go...I’m still in two minds but the three year itch has started...
Drybeer
PostPosted: Fri Mar 29, 2019 10:32 pm    Post subject: Reply with quote
M
I THINK Alex means that if there is borescoring damage in addition to the requirement of an improved IMS bearing then he's estimating £4000.
Personally I was reckoning circa £2000 at somewhere like Autofarm - but it was only a guess. I might call them to enquire.
