997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
Mat138l
PostPosted: Sat Mar 23, 2019 8:23 pm    Post subject: 996 roof bars wanted Reply with quote
As above after a set of bars for me 996 and Been told 997 fit too. Post would be great unless collection around Yorkshire ish
wasz
1999 Porsche 996 Carrera 2
PostPosted: Sat Mar 23, 2019 8:43 pm    Post subject: Reply with quote
Sorry mine are not for sale... but a couple of tips for you:
Check the screws come out of your roof fittings. The bars screw into the roof, flip the flaps open and check you can undo the grub screw thats protecting the threads.
Mine had steel screws in seized solid, I had to drill and tap. Or you can replace the insert (drop the interior trim) £14 each from OPC.
If you can't find genuine bars, then thule do a kit that works great, I had them before I found my genuine bars. You need 2 different footpacks though to make it level. See "Yacht Broker"'s post here, exeter roofrack will send you what you need. http://911uk.com/viewtopic.php?t=119825
Magic919
PostPosted: Sat Mar 23, 2019 9:13 pm    Post subject: Reply with quote
The bars are 996 and they are the same ones you use on the 997. Only one type.
997.2 C4S PDK
