997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
Grum
PostPosted: Fri Mar 22, 2019 10:00 pm    Post subject: Zunsport Grills for 997.2 Reply with quote
New 997.2 owner with OPC warranty. Would like to fit grills to protect rads (x3). OPC warranty does not allow this I understand. Was wondering if the Zunsport grills can be easily mounted/dismounted, so that when the car goes in for service/health check/111 point check, the grills can be "popped off" and then "popped back on" afterwards?
993 Carrera - Midnight Blue - Gone
986 Boxster 2.7 - Guards Red - Gone
997 Carrera S (Gen 2) - Basalt Black
911Time
PostPosted: Fri Mar 22, 2019 11:40 pm    Post subject: Re: Zunsport Grills for 997.2 Reply with quote
Grum wrote:
Hi Grum, can't answer your question regarding a pop-off version but having just bought a 991.1 with OPC warranty I fully intend to fit the Zunsport grills to my car to protect the rads (7 grills in total in the 991). Unless someone can make a very strong case how the fitment of these grills would interfere directly with any other system on the car, I really can't see how it could be an issue - they mount into plastic, clip or screw into place and are nothing but a benefit.
They may be a non-standard fitment (unlike the GT cars, on which Porsche sees fit to install grills) but why therefore they should be deemed a problem on non-GT cars Dont know
Mark
I'm not a perfectionist - I just want everything done 'Right' Wink
Current: GT Silver 991.1 C4S with a few 'special bits'. Previous: C63 Estate, BMW e92 330d Coupe (700Nm/Custom Exh/Map/BBK/Quaife/Breytons), ML63AMG, Alpina e46 B3S Coupe, Alpina e36 B3 Coupe, Lotus Excel SE, Alfasud Green Cloverleaf Ti, Lancia HPE, Capri 2.0S, Marina 1.8 (don't laugh it was my first road car) plus boring company cars. Bikes: Suzuki TL1000R and BMW R1100S AC Schnitzer.
easternjets
Watkins Glen
PostPosted: Sat Mar 23, 2019 5:56 am    Post subject: Reply with quote
I have them on my car and transferred them from a gen 1 to a gen 2 turbo, once you've seen how they clip on and off they're pretty much a 15 minute job to do. They're not the prettiest things in the world but the damage they prevent is well worth it.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
nigel99
2009 Porsche 997 Carrera 2S
PostPosted: Sat Mar 23, 2019 6:25 am    Post subject: Reply with quote
2 min job to replace them. I have two front grills, one with a number plate attached and one without. I regularly swap them around and just use a pair of long tip pliers with a bit of tape around so I don't scratch the grills.
Current: 997.2 C2S, Audi TTS mk3
Previous: Cayman 987.1, Audi TT mk1 , BMW e46
Magic919
PostPosted: Sat Mar 23, 2019 6:54 am    Post subject: Reply with quote
They go on and off, as described.
I bought them and can’t bear to fit them as they look too ugly. Make sure they are what you want.
997.2 C4S PDK
nigel99
PostPosted: Sat Mar 23, 2019 6:57 am    Post subject: Reply with quote
Here's mine on.
 Filesize:  402.41 KB
 Viewed:  886 Time(s)
rigsby99
PostPosted: Sat Mar 23, 2019 7:26 am    Post subject: Re: Zunsport Grills for 997.2 Reply with quote
Grum wrote:
The warranty is NOT invalidated by fitting grills, read it. Only if the grills can be determined as the cause of a claim can it be declined. Renewal is different as the OPC can decide what they like.
easternjets
Watkins Glen
PostPosted: Sat Mar 23, 2019 7:29 am    Post subject: Reply with quote
When you see the rubbish that comes out from the side rads and condensers you'll be convinced that they're worth it, unfortunately a 911 is like a vacuum cleaner going along the road sucks up anything and everything. Its all the rubbish that gets wet and starts to rot your condensers and the chippings that pummel your radiators.
I've seen some good home made rads made out of disposable bbq mesh if you wanted a DIY fix, lot cheaper as well.
997 Turbo Gen 2
Porsche 928 S4
Grum
PostPosted: Sun Mar 24, 2019 9:14 pm    Post subject: Reply with quote
Thanks all for reponses. Closer look needed methinks.
easternjets
Watkins Glen
PostPosted: Mon Mar 25, 2019 12:16 pm    Post subject: Reply with quote
This is what came out of my side ducts.
997 Turbo Gen 2
Porsche 928 S4
 Filesize:  1.24 MB
 Viewed:  636 Time(s)
