997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 15
craig15
PostPosted: Fri Mar 22, 2019 4:46 pm    Post subject: Brake Upgrade for 3.6 Reply with quote
Hi All
I'm just looking to get peoples opinion on brake upgrades that are available for Carrera 3.6's with 19" wheels. I've been looking at whats available for a while now and even ordered a brake kit last week only to be told that it was a 12 week lead time, so cancelled that.
I'd like to think I know what I should do but I was about to order something that probably a lot of people would advise against. Smile But thats' just modifying cars for you.....
I'd like to get bigger diameter discs and bigger pads to give more stopping power. I know Brembo kits are the solution but I'm not prepared to spend £4k or whatever it would be (I'm a tight Scotsman....!)
I've thought about Giro discs to get to 340mm (compared to my standard 318mm). They seem quite expensive (about £1200 for two discs) and you still end up with the same size pad. I know they will be great quality but still.
I don't think there is an OEM larger caliper that fits my hubs (unless somebody can tell me otherwise?) that allows 355mm or larger discs. Would love to be proven wrong on this one.
So I've been looking at DesignTek 6 or 8 pot calipers with 355mm or 380mm discs. I think the 6 pots can use Pagid RS29 pads but I'm not sure if Pagid pads fit the 8 pots? But these were on a 3 month lead time. So now I've been asking around trying to find distributors for Eurocup GT calipers (which I suspect are the same thing as DesignTek so I'm hoping they also accept Pagid pads).
Has anybody fitted either DesignTek or Eurocup calipers?
https://www.eurocupgt.com/acatalog/Eurocup_Porsche_Brake_Kits.html
I don't daily drive my car so I'm not worried about wearing brakes out or squeaky pads.
I know I should probably just fit new quality discs and Pagids but if I'm spending money I like to improve where possible. Slippery slope....
Craig
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Fri Mar 22, 2019 5:44 pm    Post subject: Reply with quote
Hello Craig
Are you modding for a particular purpose, performance, looks, other?
Do the 3.8 brakes not fit? - would have expected some used deals to be available on them, plus plenty of disks and pads available.
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Fri Mar 22, 2019 6:06 pm    Post subject: Reply with quote
Where are you based Craig? Still in Scotland?
Have a look at mine, not sure if they’re brakes from carrera S fitted to my carrera, or just painted callipers. I’ll measure disc diameter later.
Carrera 2 on 19’s.
TonyC911
PostPosted: Fri Mar 22, 2019 7:18 pm    Post subject: Reply with quote
Personally I would just upgrade to the Brembo set-up on the Carrera S. They perform well, parts are plentiful and they look good too!
Something like this - https://www.ebay.co.uk/itm/911-996-997-Porsche-Calipers-Front-And-Rear-Monoblock-brembo-VW-VAG-AUDI/153326954271?
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
craig15
PostPosted: Fri Mar 22, 2019 11:40 pm    Post subject: Reply with quote
Hi, thanks for the replies.
Jonno / James / Tony
I'm pretty sure 3.8 brakes don't fit. When I first started looking I thought I was onto a winner because I have shiny red calipers and I thought the car had been spec'd with 3.8 brakes, but I've actually only got 'little reds', lol. The 3.6 has calipers with 130mm bolt pitch (same as the 996 I think). The 3.8 has a bolt pitch of 142mm (I think). That'll be why brake kits are advertised as '996 & 997 Carrera 3.4 & 3.6'. So that rules out a good few options.
I have the same calipers as in Tony's Ebay link (996 part number)
This thread is useful.
https://www.6speedonline.com/forums/997/374203-gt3-brake-conversions-facts-997-1-s-non-s.html
I love the feel of my brakes. They give great modulation hammering into a tight corner. That's what I don't want to ruin. None of the DesignTek or Eurocup suppliers can tell me what the piston diameters are to compare it with my current calipers.
But during a 4am, summer month, 200 mile blast across Scotland on Cup 2 tires my current brakes definitely 'wilt' a little. They feel like they are hauling down a 1400Kg car...... I want it to feel like they are hauling down a 1000Kg car, Smile
When you look at the difference in brake pad area between my calipers (first link below) and the pads that fit the DesignTek 6-pots (second link below) its pretty substantial.
http://www.pagidracing.com/en/product-search/race-products/racing-brake-pads/shape-detail/s/shape-2405.html
http://www.pagidracing.com/en/product-search/race-products/racing-brake-pads/shape-detail/s/shape-8018.html
Craig
vlad
PostPosted: Sat Mar 23, 2019 7:48 am    Post subject: Reply with quote
If you're not tracking it OEM should be ok have you looked at upgrading the fluid and pads as a first step. Before you spend the big bucks 😀
This was the consensus on here a few years back when I was looking to upgrade the brakes on my C4S.
NLW73
PostPosted: Sat Mar 23, 2019 11:15 am    Post subject: Reply with quote
Put the 997 Gt3 cooling ducts on to help with cooling . They are dirt cheap and will help. Will get part numbers too you and at £20 for the fronts it’s worth doing
I would do pads and steel lines as well as better fluid to see how you get on
Could you space out the calliper to put the bigger S discs on from the 3.8?
997 C2s Schwarz
craig15
PostPosted: Sat Mar 23, 2019 12:25 pm    Post subject: Reply with quote
Hi
Yip cooling ducts sound good, didn't realise they could be so cheap either, I thought they were £70.
Yes, I totally agree with going for better pads. I'm thinking Pagid RS29's, for what ever I do, about £250-278 I think.
Hoses, might as well do them too, £79 for Goodridge?
NLW73 - Yes I like the idea of spacing out my existing calipers. That's what led me to look at the Giro disc kits. I think they come with a spacer bracket to get to 340mm discs. But £1200 for 2 discs and a couple of brackets.... I'm sure I could draw up my own brackets (I'm a design engineer by trade) but it could end up being a bodge-job challenge, hahaha. I'd rather buy something like that from a reputable company. The other thing I'm not sure about is that the 3.8 discs are 34mm thick and the 3.6 discs are 28mm thick. Would that mean I'd have to sand off 3mm per pad from my expensive new Pagid pads?? Not sure. I've not been able to find a supplier for these spacer brackets unless anybody knows otherwise?
I know all you're comments are the logical thing to do but I also know how my brain works, lol. I'd buy standard size Brembo discs and Pagid pads, everything would work great with an improvement over what I've got just now but a couple of months later I'd be wondering if the 6-pots and 355mm discs would be even better but I wouldn't want to throw £434 worth of Brembo's and Pagids in the bin to find out, then I'd be annoyed with myself. Rolling Eyes Smile
vlad
PostPosted: Sat Mar 23, 2019 2:19 pm    Post subject: Reply with quote
please check the price of the cooling ducts at OPC first - there are quite cheap IIRC , less than what some traders on ebay ask.
NLW73
PostPosted: Sat Mar 23, 2019 2:41 pm    Post subject: Reply with quote
vlad is spot on. don't buy them on ebay as traders are putting mark up.
go straight to OPC with these part numbers and prepare to be amazed at the low price! they were £20 for the fronts AND rears when I bought them last year. its a motorsport part so they won't be on the shelf but easy to order in.
bolt onto the wishbones the same as you oem ones. if they are still on there as sometimes they come off and that does not help braking and cooling too.
you might as well chuck the rear ones on as well as for £20 you can't go wrong fella!!
997 GT3 front and rear brake ducts part numbers and price:
997 GT3 Front Ducts - £2.18 each plus vat
997.341.483.92
997.341.484.92.
997 Rears - £6.30 each plus vat
997.331.487.92
997.331.488.92
yes pagid are a good option and RS29s are superb. together with braided hoses it should make a big change.
997 C2s Schwarz
James M-S
PostPosted: Sun Mar 24, 2019 12:02 am    Post subject: Reply with quote
Great tip on GT3 cooling ducts, Thanks NLW! Cheers
James M-S
PostPosted: Tue Apr 02, 2019 2:46 pm    Post subject: Reply with quote
Has anyone noticed a difference after fitting braided hoses? OE hoses are braided internally, so surely it is just cosmetic?
I would have thought bang for buck; money is best spent on:
GT3 cooling ducts,
updated brake fluid,
braided hoses.
In that order Question
I’m due a brake fluid change in coming months, and planning my first track time at a Donington evening session.
I have standard c2 ‘small reds’ same is OP.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Apr 02, 2019 3:11 pm    Post subject: Reply with quote
Unless you have a problem with your brake lines you won't notice the change to braided lines.
craig15
PostPosted: Wed Apr 03, 2019 12:00 pm    Post subject: Reply with quote
Great information on the cooling ducts!
Quick update from me. Against all you're logical and sound advice I decided to order a set of the Eurocup GT brakes. Before I ordered them I asked what the caliper piston diameters are but they couldn't tell me, only that the kit is plug-and-play for my car. After I had ordered them and then heard nothing for a week I was starting to doubt my decision and wanted to get the technical specs of what I was buying. The supplier then managed to tell me the piston diameters and surprise surprise when you do the calcs they require 30% more fluid than my current 4-pot calipers. So I cancelled them.
I'm now talking to HiSpec Brakes who sound much more on the ball. Lots of options to look at. I'll let you know how I get on.
http://www.hispeccalipers.co.uk/monster6x-range.html
http://www.hispecmotorsport.co.uk/360monster.html
Craig
James M-S
PostPosted: Thu Apr 04, 2019 2:50 pm    Post subject: Reply with quote
Can someone confirm the brake fluid capacity of a 997.2?
Do I need 1L or 1.5L or 2L?
Just about to order some Motul DOT5.1 from Opie along with Millers oil for my next service.
