996 : 1997-2005 29
Boxster : 1997- 17
Cayman : 2005- 20
911rpd
PostPosted: Thu Mar 21, 2019 5:15 pm    Post subject: Health Check @ Cridfords = a massive bill! Reply with quote
evening all - spent the morning down in Cridfords today getting an MOT, health check and an annual oil change and it threw up some interesting areas of the car which needs attention..... and comes with a £4k bill!
Needs tyres - kinda knew this was coming up and reading about PS2 vs PS4, talked to a guy in Camskill and he is saying that I can only go with PS2 for N rating - but looking on here people ignore that and still go for PS4. However I am running the wider Carrera Sport 19' wheels so I need 235/35 & 305/30 - am I right in thinking and what this chap told me; I have to run PS2 as the rear is 305 section....? Any C4S owners can point me in the right direction?
FYI this week a set of PS2 from Camskill are £778.00 - Blackcircles and F1 are a good £50/70 more.
More interesting question is around the suspension, I need to get the front sorted out as its corroded pretty badly so shocks,bump stops,collars & mounts are coming in at £1500 - it then needs a geo check which might throw out some problems with the rear but we won't know until its checked and aligned.... I was looking at an Ohlin Road & Track set up but its a bit punchy £3.5/4k - can anyone on here give me some direction on different set ups I could look at or should I stick with OEM/OP parts?
The car is going to visit a couple of tracks this year but 80% of the use will be on road.
Apart from that had a lovely morning sitting there doing some 'work' but drooling over the 993 c4s, stunning car waiting prep but coming in at £85k - and the 997.2 turbo they have at 89k....
Thanks for any input!
FZP
Paul Ricard
PostPosted: Thu Mar 21, 2019 5:45 pm    Post subject: Reply with quote
Tyres: you only need PS2 if you wear socks and sandals, or want to renew your Porsche warranty. Otherwise PS4S are the go to tyre.
As for the suspension stuff, I'd be going to see the guys st Centre Gravity. Top of their game, will give you the best advice for you. I had an issue which a other party suggested a full refresh. Turns out I needed 2psi of air in my tyres. I got them to do a more focus and sporty wheel alignment and couldn't have been happier
My 2 cents
resigner
PostPosted: Thu Mar 21, 2019 5:46 pm    Post subject: Reply with quote
PS4S. Note the S. PS4 are a different tyre.
PS4S are the best, by a distance. If you have an OPC warranty, you need N rated. If you don't, you don't.
jl-c
PostPosted: Thu Mar 21, 2019 6:42 pm    Post subject: Reply with quote
295 or 305 depending on manufacturer. Either works.
basildon993
PostPosted: Thu Mar 21, 2019 6:49 pm    Post subject: Reply with quote
I have P4Ss in 305/30 on the rear of my Turbo, what’s the issue? Dont know
997.1 Turbo Coupe Manual
ex 993 Carrera 2 Manual
ex 3.2 G50 Carrera Targa Manual
ex Chevrolet Camaro IROC Z Manual
Rojdog
PostPosted: Thu Mar 21, 2019 7:15 pm    Post subject: Reply with quote
My car was looked after by cridfords (previous owner) have all the receipts, on every bill or service they stated 'front forward arms chattering.'
The handling wasn't as it should be so took it to centre gravity expecting to need new front arms - only thing wrong turned out to be old tyres. Changed them and transformed the car.
Personally wouldn't go anywhere other than centre gravity for suspension work, their labour rates are very reasonable and they simply are the best around.
PostPosted: Thu Mar 21, 2019 8:17 pm    Post subject: Reply with quote
First off .. a post here about VHC checks ..
http://911uk.com/viewtopic.php?t=132847
Front bump stops perished .. er .. i kinda report that on almost every check i do .. you cant change them with out the strut off .. not worth doing on their own.
Bump stop is there to protect it should you bottom out the suspension .. dont do any jumps off bridges like Smokey and the bandit and youll be fine !
No mention of knackered top mounts i take it ?
Front shocks corrded .. yup .. whats new .. are they leaking ? nope i thought not .. its not broken.
Lots of bits on cars are corroded .. you dont have to replace them for that on its own.
Play , leaks or bushes split and debonding .. then its worth it .. my guess is yours is just like a lot of the cars i see ..
You can spend the money if you wish .. is it actually needed .. hmm .. if its not a red flagged item then nope .. it aint .
Tyres wear out .. so thats a normal cost .
Over all though .. thats a pretty small list and nothing urgent .. a result in my book .. i would have been much harder Razz
FRZ 911
2007 Porsche 997 Carrera 4S
PostPosted: Thu Mar 21, 2019 8:24 pm    Post subject: Reply with quote
For OP
I have a C4S and am running 305 PS4S on the rear without any issue. Thumb
997.1 C4S Meteor Grey Manual
DucatiRob
PostPosted: Thu Mar 21, 2019 8:43 pm    Post subject: Reply with quote
Can thoroughly recommend Ohlins R&T, had them installed at Centre Gravity along with new lower control arms, diagonals, top mounts, ARB bushes and track rods, plus full geo and corner weighting. You are pretty much spot on with the cost, but in my opinion, worth every penny, the difference is frankly light and day! If you intend to do track days, they are a doddle to adjust too Thumb
Mercedes CLK DD
Ducati 996
Magic919
PostPosted: Thu Mar 21, 2019 8:48 pm    Post subject: Reply with quote
I have the 305 PS4S on the rear of a C4S. Wouldn’t dream of mixing them with PS2. I have 305 PSS on the C2S as I have the Carrera Sports.
997.2 C2S PDK
997.2 C4S PDK
cheshire911
Estoril
PostPosted: Thu Mar 21, 2019 8:57 pm    Post subject: Reply with quote
I would also recommend Centre Gravity. Chris and Pete know their stuff and good labour rate. They give the car a thorough, comprehensive, structured assessment and you can stay throughout the whole session. Very good business model.
996 2002 X50 Turbo Manual
Marky911
PostPosted: Thu Mar 21, 2019 10:10 pm    Post subject: Reply with quote
Ignore Camskill sales guys.
I bought my Federal 595RSRs and rang them for an invoice as they hadn’t sent it.
The guy on the phone says “they aren’t N rated”, to which I replied “Yes I know, it doesn’t matter”, so then he enters into an argument that it did matter for insurance etc etc.
I pointed out that it really doesn’t matter at all and insurers are only bothered about tyres being legal, the correct size and correct pressures. The speed rating doesn’t even matter as the limit is 70mph.
Disgruntled he ended by saying “Well anyway, those are summer use track day tyres so you aren’t insured if you go out in the rain. If you have a crash and it’s wet your insurance is void”. Floor
I knew then it was time to end the conversation. Rolling Eyes
The Ohlins is pricey but very good. I thought it was nearer £2k than £4K though??
It’s all the other stuff that will add up such as coffin arms, fork arms, etc etc.
Research it and gather the parts yourself from CP4L, eBay, ECP etc.
You’ll need all new eccentric bolts from Porsche though and they add a chunk to the bill on their own.
Jay.
PostPosted: Thu Mar 21, 2019 11:15 pm    Post subject: Reply with quote
On my last major service they noted the front bump stops needed replacing and that the front top mounts were "starting to go" - I had a check myself and whilst they look a little worn they're certainly not bad.. What's the issue with the top mounts going? .. I guess the rubber splits and then it hits the metal?
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Follow me on Instagram! @rb.240z
MaxA
PostPosted: Fri Mar 22, 2019 8:44 am    Post subject: Reply with quote
This kind of upselling is sadly all too common. I was once advised that my 19" Carrera Sports were all bent, wouldn't balance, and needed replacing. When I had them tested at an independent wheel place, this turned out not to be the case: I could see for myself on the machines that they balanced up just fine. And they're still fine, now being wrapped in winter tyres and rebalanced annually.
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
michaelbbwalker
2005 Porsche 997 Carrera 2S
PostPosted: Fri Mar 22, 2019 6:18 pm    Post subject: Reply with quote
are you sure? i thought the PS4S was just the same as PS4 but it became an "S" when it was 19 inches or larger - at least i read that somewhere on here anyway.
PostPosted: Fri Mar 22, 2019 7:18 pm    Post subject: Reply with quote
Top strut mount has a large rubber bush in it , it will start to debond over time .. seperate from the metal basically .. we have limited vision of this but can see on a lock to lock turn when its starting to seperate ..
Normal is just an advise .. front shock top mounts starting to debond .
The bump stops .. is a kinda dense foam item .. it does get the worse of the elements thrown at it and starts to fall appart as it gets a bit old .. not really due to damage i feel .. i think its more age related .. but thats just my thoughts .
Im afraid you have to bear in mind .. i inspect a car and report what i see .. its normally an amber .. in other words im letting you know but its not something i consider worth doing atm .. if i do it will either be a red item or i will make a note saying to do it soon and the reason .
Ie .. exhaust flange studs heavily corroded .. that would be an amber as they are not leaking atm .. my advise would be .. you have 3 monthes to get it done as thats what i think .
So some ambers are a " get it done now " .. most are a .. lets see next service .... 2 years away .
OPC and i refer back to link above .. the service advisors there SELL amber items reguardless .. always see the mechanics comments .
replace " I " with any garage as this is basically what i assume we all do .
trent
PostPosted: Fri Mar 22, 2019 10:54 pm    Post subject: Reply with quote
Guys,
I'm always wary of on-line 'cheap' tyre wholesalers as I've been caught out with tyres that have been manufactured a couple of years or more before I set my eyes on them. Is this others experience?
Porkaholic
PostPosted: Sat Mar 23, 2019 5:00 am    Post subject: Reply with quote
Ouch £4K service! Hope you don't have any more big bills for a while.
Just had my bi annual interim service, plus new belts, air con regass top up and ten year inspection. Good to look at car on the ramp with Porsche technician and discuss what's going on underneath.
Bit of superficial surface corrosion starting on shocks but otherwise ok. £740.00 bill OPC Exeter, paid it quick and ran away feeling very happy. Nice toys in the showroom too inc GT3RS and 997.2 Turbo. ££££££!!!!
Obviously I think if your car is a bit of a garage queen you can get away with almost normal car running costs but once age, track days and highish mileage comes into play then it's going to cost as stuff wears out.
2009 997.2 4S manual cab, light mods
2017 Cayenne S
2015 Mini
Magic919
PostPosted: Sat Mar 23, 2019 6:57 am    Post subject: Reply with quote
trent wrote:
Guys,
No, quite the opposite. I’ve only had old tyres from a bricks and mortar local place. Online cheap places were fresh.
997.2 C2S PDK
997.2 C4S PDK
rigsby99
PostPosted: Sat Mar 23, 2019 7:36 am    Post subject: Reply with quote
Why do you need a N rated tyre with a Porsche warranty? If you blow the engine will they refuse cover because they don't like your tyres? Read the policy.
