Boxster : 1997- 20
Curious2
PostPosted: Thu Mar 21, 2019 5:11 pm    Post subject: 991.1 Adjusting Headlights for France Reply with quote
On behalf of a friend with a 2016 991.1 C4S. Can’t find anything in the owners manual about this. Standard Xenon lights with PDLS not LED. It’s not adjustable via the PCM as it is in my 991.2. Phoned the dealer and they said bring the car in and we will take a headlight out to determine how to do it !! Any body got any knowledge on this ?
Current : 991.2 C2 SC PDK
Macan S petrol
Previous: 2015 Cayman 2.7.
pzero
PostPosted: Thu Mar 21, 2019 5:21 pm    Post subject: Reply with quote
If it's like the 997 it's a pretty straightforward procedure. Easy removal of the headlight and throwing a switch in the removed unit.
Details here;
http://www.911uk.com/viewtopic.php?t=102536&sid=17997b5c31ce72b7407f18a6988526de
991.1 Carrera GTS
MJA911
2012 Porsche 991 Carrera
PostPosted: Thu Mar 21, 2019 6:51 pm    Post subject: Reply with quote
This has come up a few times on the PCGB forum.
Summary from that is it's not worth worrying about, the lights have a flat beam that doesn't aim to the left, but if you are concerned buy some stick-on beam converters and put them your glovebox to take with you.
https://www.porscheclubgb.com/forum/tm.aspx?m=993214
https://www.porscheclubgb.com/forum/tm.aspx?m=970943
https://www.porscheclubgb.com/forum/tm.aspx?m=771904
991.1 C2, 986 Boxster S
Past pleasures: 997.1 GT3, 997.2 C4S Cab, 993 C2, 997.1 C2S, 996.1 C4
Magic919
PostPosted: Thu Mar 21, 2019 8:52 pm    Post subject: Reply with quote
I’ve never bothered changing as there’s no point.
997.2 C4S PDK
911Time
PostPosted: Fri Mar 22, 2019 10:12 pm    Post subject: Reply with quote
Hi Curious2, I have a 2013 991.1 C4S, fitted with Standard Xenons and PDLS and it looks like it's adjustable via the MF display. It's certainly an option on mine - navigate in the MF display to: "Vehicle, Settings, Light & Visibility, Exterior Lights", Select "L/R driving" and conform. Select "Standard" (RHD here) or "Inverted" (LHD for Europe).
Info can be found page 233 and 106 of of the Owners Manual.
Hope that helps
Smile
Mark
I'm not a perfectionist - I just want everything done 'Right' Wink
Current: GT Silver 991.1 C4S with a few 'special bits'. Previous: C63 Estate, BMW e92 330d Coupe (700Nm/Custom Exh/Map/BBK/Quaife/Breytons), ML63AMG, Alpina e46 B3S Coupe, Alpina e36 B3 Coupe, Lotus Excel SE, Alfasud Green Cloverleaf Ti, Lancia HPE, Capri 2.0S, Marina 1.8 (don't laugh it was my first road car) plus boring company cars. Bikes: Suzuki TL1000R and BMW R1100S AC Schnitzer.
Curious2
PostPosted: Mon Mar 25, 2019 8:29 am    Post subject: Reply with quote
Thank you very much 911 Time, all sorted with your help.
Macan S petrol
911Time
PostPosted: Mon Mar 25, 2019 9:58 am    Post subject: Reply with quote
No problem Thumb
Mark
