991 : 2011- 19
997 : 2004- 72
993 : 1993-1998 7
Boxster : 1997- 32
Paynewright
PostPosted: Wed Mar 20, 2019 9:30 pm    Post subject: Esco Axle (jack) stands UK Reply with quote
Never been 100% happy with my machine mart axle stands on the 996 - the top \_/ is slightly narrower than the jacking points.
Esco flat top stands look perfect but cannot find them in the UK.
Any suggestions for alternatives? Vigor look similar but not quite the same?
Regards
Ian
PS apologies if done to death before!!
Ghianightmare
PostPosted: Thu Mar 21, 2019 7:55 am    Post subject: Reply with quote
I have this issue too. Luckily I get to the US a few times a year with work and have looked over there too. The problem is that anything I have seen with a decent flat top are very expensive. I had contemplated welding on flat tops and using a hockey puck on top as suggested on the www, but I don’t think that is ideal either.
Until I have money that I don’t need to spend on car parts, i’m Sticking with my Halfords stands.
Not sure if this helps, so just letting you know you are not alone!
2002 Seal Grey C4S
Paynewright
PostPosted: Sat Apr 20, 2019 8:51 pm    Post subject: Reply with quote
Currently pondering welding some 10mm thick X 75mm dia mild steel discs onto some stands with some thick rubber bonded on top.
Esco seem illusive in the UK!!
Ian
rdodger
PostPosted: Sat Apr 20, 2019 9:12 pm    Post subject: Reply with quote
ebay 282800526462
Basically ice hockey pucks contoured to fit a standard axle stand.
maldren
PostPosted: Sun Apr 21, 2019 9:09 am    Post subject: Reply with quote
I use a piece of rubber cut from an old car tyre, a cheap (free) solution that work well.
Mike
Paynewright
PostPosted: Fri Jun 14, 2019 7:17 am    Post subject: Reply with quote
Its great having friends who are expert fabricators. New tops for the axle stands my dad made in the 70s. Just need to stick some rubber on the top!
 Filesize:  1.29 MB
 Viewed:  1080 Time(s)
coullstar
PostPosted: Fri Jun 14, 2019 9:41 am    Post subject: Reply with quote
There was someone on here that did the pucks moulded to slot into the jacking points. They are super handy.
Just remember to take them out when your finished.
Ghianightmare
PostPosted: Fri Jun 14, 2019 9:44 am    Post subject: Reply with quote
Nice job. I had looked at the off the shelf versions but couldn’t justify the cost. Must find a mate that can fabricate - unless someone in here wants to offer their services and do a bulk buy/ production...
2002 Seal Grey C4S
AslanC2S
PostPosted: Fri Jun 14, 2019 9:55 am    Post subject: Reply with quote
Hi didn't trust the jack stands either so made up these.
20 quids worth of MDF and some time.
Work a treat.
997.1 C2S
Audi TT 225
Toyota Supra TT
TVR T350t
Toyota Supra TT
Toyota Celica GT4
 Filesize:  81.9 KB
 Viewed:  1009 Time(s)
AslanC2S
PostPosted: Fri Jun 14, 2019 9:56 am    Post subject: Reply with quote
In action.
997.1 C2S
Audi TT 225
Toyota Supra TT
TVR T350t
Toyota Supra TT
Toyota Celica GT4
 Filesize:  154.39 KB
 Viewed:  1006 Time(s)
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Fri Jun 14, 2019 4:12 pm    Post subject: Reply with quote
Now that is the best use for MDF I think I have ever seen worship
You don't have a note of the dimensions do you?
Might be a trip to B&Q for me this weekend Very Happy
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
MovieStar99
PostPosted: Fri Jun 14, 2019 7:26 pm    Post subject: Reply with quote
These look as if they would do the job:
https://www.ebay.co.uk/itm/Porsche-Axle-stand-Jack-pads-Hard-Rubber-911-964-993-996-997-991-Boxster-Cayman/273516844526?hash=item3faedfd5ee:g:MFoAAOSwstNccl4E&frcectupt=true
Ghianightmare
PostPosted: Fri Jun 14, 2019 10:57 pm    Post subject: Reply with quote
Interesting that 10 of your 11 posts are related to jacking and you promote this product quite a bit...
2002 Seal Grey C4S
AslanC2S
PostPosted: Sat Jun 15, 2019 4:52 am    Post subject: Reply with quote
Top sections were 200mm x 200mm and the bottom I did 200 x 300 just for a bit of added stability.
997.1 C2S
Audi TT 225
Toyota Supra TT
TVR T350t
Toyota Supra TT
Toyota Celica GT4
