997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
trent
PostPosted: Tue Mar 19, 2019 10:54 pm    Post subject: Sport Seats retro fit into 997.2 Reply with quote
Have trawled the threads trying to get a definitive answer on this so I'm hoping someone out there has already completed it and can confirm either way.
The 997.2 I'm buying has manual (but heated) comfort seats. If I removed them and fitted a pair of electric heated Sport Seats (from another 997.2) will the electric function (fore/aft movement, height adjustment, lumber etc) on the seats work in my car? Just no memory function.
Look like they will and it's plug and play but just want confirmation before acquiring the seats.
Thanks,
Martin
trent
PostPosted: Mon Mar 25, 2019 8:34 pm    Post subject: Reply with quote
Anyone out there done this and can advise?
997.2 Carrera 4S Cabriolet PDK
160dmb
PostPosted: Mon Mar 25, 2019 10:03 pm    Post subject: Reply with quote
I have comfort and sports seats and have switched them back and forth and everything worked. Neither set are memory or heated but all the fore/aft and other functions worked.
Easy change, just make sure you have ignition off throughout the change (not even key in the ignition) because once you get the airbag light on - which happens if you turn ignition on without seats connected - you need a code reader to extinguish it.
trent
PostPosted: Mon Mar 25, 2019 11:29 pm    Post subject: Reply with quote
Thank you Sir, that sounds encouraging.
I have heated seats and the seats I'm looking to fit are heated so I'm sure that part with be compatible.
I'm guessing the memory is connected with the car and not the seat so that the car tells the seat to move when unlocking etc.
Magic919
PostPosted: Tue Mar 26, 2019 8:21 am    Post subject: Reply with quote
Sports seats or sports adaptive seats?
997.2 C2S PDK
997.2 C4S PDK
trent
PostPosted: Tue Mar 26, 2019 9:29 pm    Post subject: Reply with quote
Adaptive seats? >>>
 Filesize:  291.79 KB
 Viewed:  457 Time(s)
