997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
Jay.
PostPosted: Tue Mar 19, 2019 12:26 am    Post subject: Strange whine/squeal from rear of the car when in gear (tip) Reply with quote
So I noticed this noise when I was reversing down my drive. Put it in Park to go check it out and and the noise stopped, tried to get it to occur again and had no luck..
Eventually I cycled through the gears a bunch of times (about 10, going from 2nd, to 1st, to reverse) and eventually the noise started again when I selected 1st Gear. Car is at idle and not moving. Putting it into 2nd stopped the noise, and I've not tried to replicate it since.
https://www.youtube.com/watch?v=4R6ICckZhMg
Also, someone mentioned that the engine didn't sound very healthy so I'm also trying not to panic about that thumbsup
The cars currently off the road as it's got a slow leak of coolant somewhere (around 100ml/200miles) and the battery has started draining again.. I guess things come in 3?
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Follow me on Instagram! @rb.240z
PostPosted: Tue Mar 19, 2019 6:39 pm    Post subject: Reply with quote
Im afraid the only noisei herd was the secondary air pump in operation .. this will only happen for upto 1min from cold start though so not sure if thats the noise you are refering to .
Jay.
PostPosted: Wed Mar 20, 2019 12:28 am    Post subject: Reply with quote
It could be, but the car was running for around 2-3 minutes - should I be concerned that the noise is still happening after that long? Also, it seems to only appear very occasionally when a gear is selected
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
cheshire911
Estoril
PostPosted: Wed Mar 20, 2019 8:45 am    Post subject: Reply with quote
What is the mileage? Looks like a visit to an indy is on the cards.
996 2002 X50 Turbo Manual
PostPosted: Wed Mar 20, 2019 8:04 pm    Post subject: Reply with quote
The air pump will only run for a max of 60 seconds from cold .. if the noise happens after that then thats not the fault / noise .
Im afraid i agree with cheshire911 .. it will need looking at as from the video i cant hear a problem and im guessing neither can anyone else .. getting a gargage to confirm there is or isnt a fault is safest i feel .
cheshire911
Estoril
PostPosted: Thu Mar 21, 2019 10:59 am    Post subject: Reply with quote
A lot of time can be wasted trying to figure this out and we don't have all the info to go at. Sometimes, a job is beyond reasonable DIY and its a trip to the indy to test drive it listening to the noise, check codes and put it up on the ramp. It could be diff, gearbox or anything else. No mention has been made of mileage. many of these cars are high mileage examples these days and my indy sees them all the time - whines, squeaks, rattles etc and he is doing so many diff and manual gearbox strip and repairs landing their owners a big bill.
Its so often a case of wear and tear as the miles are put on.
Jay.
PostPosted: Fri Mar 22, 2019 12:14 am    Post subject: Reply with quote
Yep, sound advice above. Thanks guys.
I'll take it over to Brookspeed next time I'm free - haven't heard the noise again since, but I'll keep an ear out and try and diagnose it a bit better in the meantime
Cars on 85k thumbsup
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
