997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
MarkGolf
PostPosted: Mon Mar 18, 2019 10:32 am    Post subject: Cayenne drive train fluids Reply with quote
Hi All,
I've got a 2008 GTS coming and I'm planning all the jobs to do on it, I want to change the differential fluids and transfer case.
Anyone recommend fluids that they have used and how much?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
MarkGolf
PostPosted: Mon Mar 18, 2019 10:57 am    Post subject: Reply with quote
I assume that to change the actual gearbox fluid, it is the usual case with using a temp gun?
As for the diffs and transfer case, i found the following;
Front diff = 1.4 litres
Rear diff = 1.6
Transfer case = 0.8
Now, what fluid? 75/90 for diffs and a generic ATF for transfer case?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
MarkGolf
PostPosted: Mon Mar 18, 2019 5:54 pm    Post subject: Reply with quote
9 litres for engine, Mobil 1 0/40. Is this still recommended for a 90k miler?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
PostPosted: Mon Mar 18, 2019 8:07 pm    Post subject: Reply with quote
pm sent.
