964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
moonigan
PostPosted: Fri Mar 15, 2019 12:50 pm    Post subject: 997.2 Plugs and belt service. Replace rusty bolts? Reply with quote
My car is booked in for a plug and belt service in April and I've read that to do this parts of the exhaust system need to be removed Question
Is it worth getting the rusty bolts replaced with stainless ones when this is done and if so which ones do I need to buy?
Paul
PostPosted: Fri Mar 15, 2019 12:54 pm    Post subject: Reply with quote
Yes.
Can't you leave it to the people doing the service to source them. Question
moonigan
PostPosted: Fri Mar 15, 2019 12:56 pm    Post subject: Reply with quote
T8 wrote:
Yes.
Its at an OPC so I suspect they will only source standard parts. I could certainly ask.
PostPosted: Fri Mar 15, 2019 1:14 pm    Post subject: Reply with quote
They might be able to advise. Worst scenario = New standard parts will be better than old ones.
PostPosted: Fri Mar 15, 2019 5:24 pm    Post subject: Reply with quote
The Porsche instructions for a gen 2 are to remove the silencer bolts and drop it then change the plugs.
Im afraid the reality is the clamp bolts are normally so corroded that this isnt possible .
So what we do is remove the pu / bumper and cut the clamps off to remove the silencers , then fit new ones.
The flange bolts which is what i think you mean are not removed to do this job , they do go rusty like all models and have to be burned out .. but not for this job ... the silencer bolts usually come out its just the clamp bolts that dont.
Job time is 1.5 hrs and not the book time of 0.8 because of the above .
Jam911
PostPosted: Fri Mar 15, 2019 7:25 pm    Post subject: Reply with quote
Sorry to jump on the post but I am doing my first DIY Major Service in a couple of weeks.
Is corrosion also an issue when removing the silencers to replace the spark plugs on a Gen 1?
Current '07 997 C4S
Ex '99 2.5 Boxster
PostPosted: Fri Mar 15, 2019 7:32 pm    Post subject: Reply with quote
You dont need to remove the silencers to do a gen 1 plug change .. only a gen 2 due to limited access .
Just remove the heat sheild and change them .. its limited access as per all 911 but an easy enough job .. says the man who works on a ramp !
Nice link to a gen 2 replacement though ..
https://rennlist.com/how-tos/a/porsche-997-how-to-replace-997-2-spark-plugs-383525
Jam911
PostPosted: Fri Mar 15, 2019 8:01 pm    Post subject: Reply with quote
Borrowing a ramp so that should be okay.
Any more Gen 1 plug replacement tips please?
Only part of the service that concerns me
Current '07 997 C4S
Ex '99 2.5 Boxster
PostPosted: Fri Mar 15, 2019 8:25 pm    Post subject: Reply with quote
you work between the silencer and the head .. remove the coil heat sheild , 10 mm or torx bolts depending on year.. easy .. probably Torx .
Unplug the coil wiring .. i prefer to move the rubber boot up then unclip the wiring plug .. makes it easyier to reinstall ..
remove coils .. T 30 , remove plugs .. its that easy .. refit with new .
I will say on the floor it is harder than on a ramp .. well its a 0.8 job to replace them on a ramp .
you wont have problems unless a bolt snaps and thats rare .
Small amount of ally grease on the new plug threads .
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Fri Mar 15, 2019 9:12 pm    Post subject: Reply with quote
Just to add, OPC won't replace with stainless , only OEM ***** mild steel.
Jam911
PostPosted: Fri Mar 15, 2019 9:17 pm    Post subject: Reply with quote
Brilliant thanks for the tips
Current '07 997 C4S
Ex '99 2.5 Boxster
moonigan
PostPosted: Sat Mar 16, 2019 8:44 am    Post subject: Reply with quote
Superb. Thanks!! thumbsup thumbsup
