997 : 2004- 69
Boxster : 1997- 13
Cayman : 2005- 14
heed
PostPosted: Thu Mar 14, 2019 6:34 pm    Post subject: Thoughts on a well-used 996 C4S Reply with quote
Hi all,
I'm considering going to look at a car that I previously disregarded on search results, but took a closer look at today. Wanted some thoughts...
    * 95K, manual C4S coupe
    * arctic silver / graphite grey interior
    * 2004
Some good things about the car
    * over 5K spent in last 2y:
    * Full Service History
    *Fron top mounts and shocks replaced
    * rads replaced
    * IMS / RMS done
    * Brake pipes replaced
    * Track rod and control arm replaced
Some bad things:
    * Graphite Grey - I think I can get past this...
    * 9 owners - seems a lot...
    * Dent in front bumper - how much for a pull and respray do you think?
    * Wheels need refurbing - what's the going rate for C5S twist wheels?
    * Exhaust boxes need doing - that seems like a £1K job but no biggie.
    * Clutch done 6y ago. Might need doing again...
I'm planning on going to see it, as I've never seen a graphite grey in the flesh before (but they do look questionable on photos...)
Without cheating... What seems like the right sort of money for this car?
Oh since it's had 9 owners: Anyone know of E U 0 4 W M T?
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu Mar 14, 2019 6:37 pm    Post subject: Reply with quote
My first question would be to ask what it means by the IMS being done?
PostPosted: Thu Mar 14, 2019 7:12 pm    Post subject: Reply with quote
That's low mileage for its age. * IMS / RMS done needs to be in the bad things section. I paid well under £100/corner last year for the full monty on the wheels. I'd say price wise £20kish
PostPosted: Thu Mar 14, 2019 7:16 pm    Post subject: Reply with quote
Cazana say £20,921 - £21,449
PostPosted: Thu Mar 14, 2019 7:23 pm    Post subject: Reply with quote
The good things outweigh the bad things - subject to clarification on the IMS bearing issue - and 9 owners in 15 years could point to it being bought and cherished 9 times rather than being passed on due to ..... whatever.
95k miles is a turn-off for many so I'd want it for under £20k.
ragpicker
Estoril
PostPosted: Thu Mar 14, 2019 7:39 pm    Post subject: Reply with quote
It seems very cheap. It there for all to see on AutoTrader.
I'd have a look but make sure you get it properly inspected if buying
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Thu Mar 14, 2019 8:08 pm    Post subject: Reply with quote
There's a c4s on eBay with an engine rebuild and seems well sorted on a 22k but could be negotiated, it's 140k miles though..
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Thu Mar 14, 2019 10:05 pm    Post subject: Reply with quote
Bought my 4S with 96k on the clock and its been a joy.
But its needed suspension work, an AOS and some attention to the brake lines, so that these have been done is a good thing.
Agree with what Alex says re wheels, bumper PU repair.
Get the IMS checked out should it need a clutch. Find out who did it and satisfy yourself they knew what they were doing when they replaced the bearing.
The 04 cars were moved to 2 yearly service intervals which is not ideal, so see how many services its had.
Go see it!
freshy
PostPosted: Fri Mar 15, 2019 12:02 am    Post subject: Reply with quote
I have Graphite Grey interior in my C4S, although it's Atlas Grey on the exterior. So a very nice contrast imo, not sure if it will have the same effect on artic silver.
It takes a little more effort to clean, but once clean looks great and makes the cabin feel a lot brighter inside.
2005 996 'C4S Plus' Cab Manual in Atlas Grey X51 + Rusty PSE
Griffter
PostPosted: Fri Mar 15, 2019 7:57 am    Post subject: Re: Thoughts on a well-used 996 C4S Reply with quote
heed wrote:
Hi all,
    * 2004
    * rads replaced
    * IMS / RMS done
Some bad things:
On balance it sounds looked after. Some thoughts:
Top mounts: these are expensive for the C4S, but are you saying only the front shocks were replaced? If so I expect the rears will need doing.
Brake pipes: if this is all the hard lines, fantastic. If it’s just the flexis then it’s no bad thing, but it’s the hard lines that are problematic.
Front bumper: remove, repair, respray about £500 depending on the repair needed.
Clutch: time won’t wear it but miles and driving style will.
Good luck. As I say, on balance sounds good. IMHO.
Robertb
PostPosted: Fri Mar 15, 2019 11:24 am    Post subject: Reply with quote
Odd that the online MOT history only goes back to '17.
PostPosted: Fri Mar 15, 2019 12:57 pm    Post subject: Reply with quote
If it's had a (or more) private plate on it at some time this can cause a gliche on the MOT history checking data base.
